No Boost After High EGT's - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-28-2014, 05:34 AM Thread Starter
Air Assault!!
MPTonyT's Avatar
Quoted: 5 Post(s)
Send a message via AIM to MPTonyT
Hey Guys,
Vehicle:
2005 6.0L - 57,000 Miles - SCT w/ Gearhead SRL
Was my daily driver but recently (6 months ago) I got a work truck so i only drive this truck on the weekends. This issue didn't start till after it started sitting for a week at a time.
Problem:
Vehicles runs great, turbo works as it should, until i do a hot run.
Get on it and run the EGT's up to 1100 or 1200 for a second and then let off. For the next 5 to 10 seconds, sometimes longer. During that time if you try to get into the pedal at all no boost builds on the pillar or dash gauge and it blows black smoke. If i stay off it for that time you can watch the gauge and the needle will jump from like 0 to 1 or 2 lbs and then i know i have boost back.
Could this be a dirty turbo? Bad Solenoid?
Thanks in advance.
2005 Ford F-250 CCSB-Lariat-FX4-SRW
SCT - Tunned By Matt @ GearHead Performance
FICM Tuned by Bill @ Power Hungry Performance
AutoMeter Gauge Kit (Boost, Pyro, & Trans)
Diesel Site Coolant Filtration System
Viper 5901 Remote Start / Alarm
Zoodad mod w/ Stealth Screen
4" MBRP Exhaust
MECP Master Mobile Audio/Video/Security Installer/ ASE A6 Certified
MPTonyT is offline
post #2 of 6 Old 03-28-2014, 05:49 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Im gonna bet your turbo's dirty and needs a good cleaning.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 6 Old 03-28-2014, 05:58 AM Thread Starter
Air Assault!!
MPTonyT's Avatar
Quoted: 5 Post(s)
Honestly I hope that's all it is. I have a new Turbo oil feed and drain tube along with an EGR delete I've been itching to put on...
4" MBRP Exhaust
MPTonyT is offline
post #4 of 6 Old 03-28-2014, 06:34 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
If you have never cleaned a turbo check out the videos on you tube. Awesome videos.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 6 Old 03-31-2014, 05:29 AM Thread Starter
Air Assault!!
MPTonyT's Avatar
Quoted: 5 Post(s)
I have cleaned two turbos (dads and buddies) but not my own yet. Looks like I will schedule some time to get it all done.
4" MBRP Exhaust
MPTonyT is offline
post #6 of 6 Old 02-13-2015, 12:53 PM Thread Starter
Air Assault!!
MPTonyT's Avatar
Quoted: 5 Post(s)
Issue was dirty Turbo. Cleaned it and installed EGR Delete, Better than new!!
4" MBRP Exhaust
MPTonyT is offline
