no boost (none) - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-26-2014, 02:36 PM Thread Starter
Unhappy no boost (none)
Please Help me!!!
Truck: 03' f250 6.0 automatic
mods: EGR Delete kit
New Stage 1 Garrett turbo w/ new VGT
SCT SF3 Programmer
Replaced: Installed EGR Delete kit, oil cooler, flywheel, torque converter, all steering components and bushings. ICP sensor
Problem: Truck has never had a lot of take off power or bottom end. So I replaced the turbo as we thought it was stuck i.e. vgt. Then still no bottom end. So I read on here and replaced the ICP and turns out it was bad, passing oil through it. I have had the truck only since may of last year and only put on about 3-5000 mi on it. Every so often with the old turbo the truck would not get boost and I would change programming modes with the sct and then all better (never no bottom end though). So I learned that I should be hearing the turbo whistle or run at idle, and have good take off power, so I realized something was wrong. I was getting codes P0046 and Keep alive memory. replaced turbo, came with new vgt. No boost still, then took out pcm checked connections, am getting power to vgt (used the pinpoint test), and put it back and worked no codes, but no bottom end power i.e. no real boost until about 2600 rpm then whoosh off i'd go like a rocket. So I replaced ICP sensor, and now get codes P0046 and Keep alive memory. checked connections at vgt and tried again and still no boost, tried reprogramming and no boost. Should I go ahead and order a new PCM or what should I do. Also where is the EBP sensor, I was going to check it and Don't know where it is, or if it is part of the EGR system. Please help me, Thanks and GOD Bless.
Mr. Darryll M, Stovall
Darryll is offline
post #2 of 8 Old 03-26-2014, 05:15 PM
Check the map sensor and the hose running to it. Mine blew the fitting out of the manifold (it was loose) and the pcm decided there was no boost so it wouldn't give the engine anymore fuel. If the hose is plugged it might take to 2600 rpm for it to register. Never threw an error code either.
wingrider is offline
post #3 of 8 Old 03-26-2014, 05:21 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 499 Post(s)
EBP is mounted to the Thermostat housing on the front of the engine (where the top radiator hose mounts to the engine). Check that plug, pull the sensor and see if its caked with soot. Also start it and make sure its getting flow and not gummed up. Good Luck
@loxdce
LoxDiesel is online now
post #4 of 8 Old 03-28-2014, 02:59 PM Thread Starter
Thanks I finally found that it's not getting good connection at the vgt plug. So now the turbo starts running in at about 2200 rpm's with the stage 1 turbo. But still doesn't have any real bottom end until that, and I checked: and have no exhaust leaks so we can eliminate that. Anyone out there have a 6.0 that has good bottom end below 2200 rpms? If so when does your's kick in.. It seems absurd that they go to all the trouble to build that turbo with the variable geometry veins and it doesn't have any more power than that on the bottom end.. or doesn't kick in faster without all that lag.
Darryll is offline
post #5 of 8 Old 03-28-2014, 04:23 PM
LoxDiesel's Avatar
Quoted: 499 Post(s)
no boost (none)
Honestly its an 03 thing. My brothers truck is 03 and it has a performance tune on it. I just put injectors in it today, test drove it. It doesn't have a great bottom end. Top end is stellar though. I believe it has something to do with the VGT strategy in this year truck. Looking at everything that's measured no wonder it takes so long.
Sent from AutoGuide.com App
@loxdce
post #6 of 8 Old 03-28-2014, 04:45 PM
midnite rider's Avatar
Quoted: 285 Post(s)
plug a good egr valve in the plug for it, then listen for the vanes to start sweeping. may take a few minutes. mine will smoke the tires from a dead stop, its an 03.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #7 of 8 Old 03-28-2014, 08:47 PM
LoxDiesel's Avatar
Quoted: 499 Post(s)
Egr is deleted
@loxdce
post #8 of 8 Old 03-29-2014, 04:50 PM
Quoted: 285 Post(s)
Are the vanes sweping on your turbo that is my question.
-Tom
Tags
boost , egr , icp , pcm , vgt
