Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
Old 12-06-2006, 06:32 PM
firetiques firetiques is offline
ultra low sulfur fuel
To use fuel additives or not.What is the manufacturer recomending?I have the 06 6.0 Do I need fuel lube? If I have a fuel related failure will Ford honor the warrantee?
Old 12-07-2006, 04:43 AM
Logan Logan is offline
The Fat Mod
If I were you, I would use it on every fill up or at least on every other one. The new fuel is real dry, and an additive will help lub it a little better.
Old 12-07-2006, 06:20 AM
BigGreen06 BigGreen06 is offline
<b>Premium Member</b>
There was an article in one of the 'Diesel Power' issues that talked about the new ULSD, and they showed a pic of it at a station, and it had another pump right next to it, that was used to select the lubrication that you wanted to add to the fuel. Don't know when that will be available, it looked like a prototype, most likely in CA.
-BG06.
Old 12-07-2006, 06:28 AM
Clay Henry Clay Henry is offline
Sooner Powerstroker Mod
I'm going to start adding a gallon of vegi oil (new vegi or filtered used vegi) to each tank of diesel. No better lub than that.
I hear about lots of people doing that with no issues.
Old 12-07-2006, 09:50 AM
06SIXLITER 06SIXLITER is offline
ket us know how that goes.. didnt you JUST replace all injectors because of burnin oil???
Maybe it was someone else??
Old 12-07-2006, 11:03 AM
No, i did just go through injectors but not because of oil.
I am burning oil again too!
