Buying a new truck - Ford Powerstroke Diesel Forum
post #1 of 24 Old 03-25-2014, 05:19 PM Thread Starter
Buying a new truck
Hi guys, new to the forum here and was looking for some advice. I am currently looking at buying a 06 f350 diesel. it has 100k on it. I have been driving them at work for several years and am pretty familiar with the motor and their problems. So I took the truck for about a half hour drive, let it get nice and warm, got on the thruway and put a good load on it a couple times. Got back to the lot and opened the hood immediately. Hood covered in coolant right above degas bottle. good puddle under the truck. Told the salesman good chance it needs headgasket. The truck drove/started/idled perfectly, no white smoke and felt like a flawless truck other than the coolant issue. He stated he would have it looked at, called the next day and stated that their shop did a compression test and sent a coolant sample to be tested for combustion gasses and they both came back normal. I don't believe that the tests were done properly. My question is could anything else cause coolant to come out degas bottle. Thanks for the help.
matt7987 is offline
post #2 of 24 Old 03-25-2014, 05:27 PM
Ordnance on coordinates
powerstrokeshellback's Avatar
Quoted: 56 Post(s)
Feedback Score: 7 reviews
sometimes the gasket is only bad under load. could have been over filled too.
God bless America, the Constitution and the Second Amendment.
powerstrokeshellback is offline
post #3 of 24 Old 03-25-2014, 05:33 PM Thread Starter
Wasn't over full, checked it before it was driven. I'm figuring it needs head gaskets. Assuming when they tested it that they didn't really put a good load on it, that's why they found something wrong.
matt7987 is offline
post #4 of 24 Old 03-25-2014, 05:41 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 350 Post(s)
Buying a new truck
Best way to do that test, which I'm sure they won't let you. Is tee in a 3/8" hose at the top of the degas tank. Make it about 15'. Run it out from under the hood in between the grill and drivers head light, across the hood, put wiper over it, through the driver door window (nothin but net). Install a 30 psi gauge on it. Then go for a ride. If she goes up to 15 psi that means the cap is doing its job and venting, hence the coolant. If it only goes up to around 5lbs then you only have a bad cap.
Edit: if it does vent with a bad cap then you'll have to replace the cap and retest to be sure.
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #5 of 24 Old 03-25-2014, 05:46 PM
Anti-Hashtag Member
starcommtrey1's Avatar
Quoted: 488 Post(s)
Could be a stopped up oil cooler causing it to puke if the EGR has been deleted. Best bet, find a 6.0 thats already bullet proofed. JMO
Only two defining forces have ever died for you, one died for your soul, and the other died for your freedom. They are Jesus Christ and the American Military Service member. So, pray to God for your soul, and Thank a Veteran for the right to do so.
2007 King Ranch CC F-350 SRW
Performance Machines EGR Delete
Performance Machines Coolant Filter
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
starcommtrey1 is offline
post #6 of 24 Old 03-25-2014, 05:53 PM Thread Starter
the motor is completely stock, looks like it has never been touched. egr looks factory, no head studs, no exhaust nothing.
Ricemiester They claim they did a pressure test on the cooling system. Exactly what they mean by that I do not know, he did not know details from the shop. I am familiar with the test you described. I thought the coolant system buiding up 15+ PSI under load was sign of bad head gasket and not a normal operating psi.
matt7987 is offline
post #7 of 24 Old 03-25-2014, 06:07 PM Thread Starter
starcommtrey1 I looked at a couple other trucks that have been bullet proofed but wasn't overly impressed with them. Seems like trucks around WNY are hard to come by lately, especially a good clean one. Thought it would be better to have the work done myself and know exactly what was done to it and that its done right. Was kind of a guessing game with the other ones I have looked at. Could tell they had studs no egr but that's about it. And they are all rusty from the brutal winters over here.
matt7987 is offline
post #8 of 24 Old 03-25-2014, 06:39 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
hey man, I would pass on the truck. You really do not want to get someone elses problem. The only way you are going to be able to properly test the coolant pressure is to put an inline pressure gauge going to the degas bottle (like stated earlier), I doubt they will let you do that. You might need to travel to get a good 6.0 in your price range, but I know there are plenty of them out there to choose from. Be patient, you'll find one.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #9 of 24 Old 03-26-2014, 08:53 AM
Mexfdmnb's Avatar
Hey you said you are located in wny? Are you close to Fulton or Oswego?
[SIGPIC]2005 F-250 CCLB zf6
leveling springs, 4" turbo back 5" tip
oil filter bypass, coolant filter
deleted, studded, sinister fuel filter cap,
SCT X3, S&B CAI, blue spring,
truxedo lowpro qt bed cover,
black diamond hg,
stand pipe, dummy plugs, stc fitting, Airdog 150,
Beans Diesel sump, edge insight cts, eadge eas pyro, turbo feed line,
Turbo drain tube, mishimoto 200* t stat, WW2
CCV MOD, High idle mod, PMF traction bars, 08 diff cover, 20" led light bar
Mexfdmnb is offline
post #10 of 24 Old 03-26-2014, 03:55 PM Thread Starter
I am in buffalo. I spoke with the dealer today. We agreed to have truck taken to the ford dealer and let them test for bad h/g. agreed that if they are bad he will take 5000 off the price for repair. Told him I would not be interested in having them fixed, would like to have it done myself.
matt7987 is offline
