Coolant and Compressor Leak - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 17 Old 03-25-2014, 04:43 PM Thread Starter
mustangcobrajc's Avatar
Question Coolant and Compressor Leak
Well Now all of a sudden i am getting a pretty big coolant leak, i think coming out of my waterpump, even though its only 2 weeks old, and also I head a air leak so i poped the hood and this big tube has liquid on it and water a white color. I am guessing it is the air compressor, but how do you fix these?
ID:	262809   Click image for larger version
ID:	262817   Click image for larger version
05 F350 Harley CCLB 6.0L
SOLD!!!
General Grabber AT2 315/75-16 w/Newton 2.5" Level
5" Diamond Eye Turbo-back Straight pipe
Garret Stage 1 Turbo, ARP head studs
Sinister EGR delete, Sinister Coolant Filter
High Idle, CCV MOD to atmosphere
Blue Spring
Mag-Hytec trans pan and Diff cover
SCT Livewire 5015 custom tuned by Quicktricks
mustangcobrajc is offline
post #2 of 17 Old 03-25-2014, 05:39 PM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
what waterpump did you use- dieselsite, BPD, or stock? Also, are you sure it is coming from the waterpump and not the o-ring that is in the metal heater hose below the alternator? (hard to tell from the pic)
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
post #3 of 17 Old 03-25-2014, 05:45 PM Thread Starter
It is a NAPA one with metal impellers. It might be coming out of both the o-ring that you said but i did see it dripping slowly from the bottom of the water pump.
SOLD!!!
Blue Spring
post #4 of 17 Old 03-26-2014, 05:27 AM
You may have more than one thing going on. The 3rd pic is of the dryer/filter of the a/c if ya got a lot of moisture there thats not good.
You will need to evac the system and dry it out, replace the dryer and check the evap core and recharge.
john galt likes this.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #5 of 17 Old 04-08-2014, 03:51 PM Thread Starter
Well looks like I am stuck trying to do the head gaskets myself since I dont have the $$$ to take it somewhere here to have it done. What all parts am I going to need to replaced during this. Also If you can please post the part # and possibly best price/place to get them.
SOLD!!!
Blue Spring
post #6 of 17 Old 04-09-2014, 07:31 PM Thread Starter
Well stuck on what all I really need to Get. I think the main thing I am going to get is the Bullet proof Oil cooler. But not sure what else I would need. I found these head gaskets Ford Factory OEM head gasket for all 6.0 Powerstroke engines with 18mm dowel pin heads. Ford OEM 18MM Head Gaskets for 6.0L Powerstroke and 6 0L Powerstroke Diesel Genuine Ford Pair of 18mm Head Gasket Kits VT365 | eBay I know there are other things i need like valve cover gaskets and some other things. Anyone that can help me out i would really appreciate it.
SOLD!!!
Blue Spring
post #7 of 17 Old 04-09-2014, 08:22 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
6.0 Head Stud Part List.
ZMANN likes this.
Please
You could save the life of a sick child
NYC F-350 is offline
The Following User Says Thank You to NYC F-350 For This Useful Post:
ZMANN (06-15-2014)
post #8 of 17 Old 05-25-2014, 07:03 PM Thread Starter
Well it looks like i am stuck and going to have to do the head gaskets my self. I ordered all new parts all the way from gaskets, push rods, lifters, glow plug and wires and much much more. Does anyone have the torque specs of everything I am going to need for the studs, lifters and everything else?
SOLD!!!
Blue Spring
post #9 of 17 Old 05-25-2014, 08:04 PM
NYC F-350's Avatar
Quoted: 49 Post(s)
Try the file I attached below..
File Type: pdf Service Manual 04-06 Part 2 (Cylinder Head and Valve Train).pdf (4.39 MB, 638 views)
ZMANN likes this.
Please
post #10 of 17 Old 06-14-2014, 05:08 PM Thread Starter
Having fun tearing it all apart finally. Hopefully get to the gaskets by Monday since the shop is closed Sundays...
SOLD!!!
Blue Spring
