Rough at lower RPM - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-25-2014, 12:07 PM Thread Starter
Rough at lower RPM
Ok I have a 2006 6.0L. I have a new engine, new ICM, and New HPOP and all new filters. When the truck starts it takes a bit to turn over. When idling it seems to miss every now and then. When I accelerate I have great power and it doesn't miss a bit. When I reach the speed I want to run at and I let of the gas and maintain the speed it will get jumpy. I can't figure it out. Any Ideas? I am on a shoe string budget and hope I can fix it myself.
scott82070 is offline
post #2 of 2 Old 03-28-2014, 07:16 AM
ps_lane01's Avatar
Quoted: 7 Post(s)
Sounds like injectors or hpo leak. The injectors are running on relatively low pressure at low rpm.. so when you put the truck under load, any injector issues or hpo leaks become much more apparent.
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
