Low fuel mileage and no answers - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-24-2014, 02:48 PM Thread Starter
Alright, you can see my mods in my signature and I can't get more than 12 mpg. And for the last few months its been like 10. I got like 8 pulling a 5000 lb camper from chicago to Billings, MT running Vivian's tow agressive. Not sure how much it matters but i have the VXCF4 strategy that PHP prefers. Also, the truck is a manual transmission. and on 285 65 18's and the tune and revs per mile are calibrated correctly.
Ive checked brakes and hubs, they are all loose and free and everything spins very easily.
I just ran down the highway at 80 for 30 miles and my turbo did stick and I had like 1-2 PSI for 5 miles until it freed up and then it ran at 10ish PSI at about 42% engine load. EBP was at 160kPa and manifold pressure stayed right with it while the VGT was stuck, and then when the turbo freed up the ebp would stay roughly 20-30 kPa higher than the manifold pressure. Does this seem like normal levels, and does it seem like an appropriate relationship between the 2? If i floored it it would hit mid 20's PSI with no problem (when the VGT wasn't stuck).
Any idea's what I have going on? Is it just the turbo even though usually it doesn't stick (noticeably)? Or do i just not notice that the turbo is sticking a little all the time and that's killing MPG?
Any advice on keeping the old strategy or updating to the current one?
I don't know enough to figure this out, any help would be great.
2006 F-350 CC LWB 4x4 manual.
ARP'S, iTSX (tuned by Vivian), Silverline Turboback, Full Force Diesel 155cc injectors, EGR delete, Barder Stage 1.
houli is offline
post #2 of 11 Old 03-24-2014, 07:03 PM Thread Starter
Is it that obvious that it is the turbo, should I look no further and start researching turbos?
houli is offline
post #3 of 11 Old 03-24-2014, 07:21 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
Could be just a sticky turbo. Did you check your map sensor hose along with your bps line? This could cause a drop in mpg, clogged fuel filters could also. just few things to check. Keep us posted.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #4 of 11 Old 03-28-2014, 08:22 AM Thread Starter
I cant do it right away but I'm thinking Barder stage 1 for a turbo replacement. What should I expect for performance increases over a stock turbo with Looney wild tuning? Should I see lower egt's? better fuel economy (than a properly operating stock turbo)?
houli is offline
post #5 of 11 Old 03-28-2014, 08:34 AM
Check this thread out.
WPE/KC DIY Turbo Kits - Testers Needed
Nate and Charlie know their chit and those racer cover look amazing. I'm not knocking mtw or barder but I think they machine your parts whereas the DIY kit include new parts. There are a lot of options, good luck.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #6 of 11 Old 03-28-2014, 08:42 AM Thread Starter
I saw that thread last week but i thought it wouldn't be an option for me because the problem with my turbo is that the pivot hole for the VGT actuator is worn out. The DIY kit wont replace that center section of the turbo will it? Also, has Vivian tuned any of these or is it similar enough to another turbo to use that tuning?
houli is offline
post #7 of 11 Old 03-28-2014, 08:51 AM
Yeah your right but for that matter I don't think any builder can do that, you would probably be better off buying a used turbo and build from a stock charger.
Vivian writes real good tunes and if you baby the truck you will save fuel but wildmans and bills are awesome too. I run bills 140x from php and I get about 20mpg and wildman's is the same. I like bills and Tonys tunes because of throttle response and no light switch effect but this is just me. Vivian's tunes are strong though, it really is a personal preference or what your truck likes.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #8 of 11 Old 03-28-2014, 09:27 AM Thread Starter
I was just reading your thread...or at least one you posted on about the 140x, sounds great. Yes vivian's tunes "light up" for sure, I think i would prefer a more smooth throttle response. One reason i would like to stick with vivian is that her tunes are free because i bought my iTSX from her. But i am running the old strategy(i didnt roll it back, it has always had it) which i know is Bill's preference so i wonder if his tune, with his atlas 40(which i have) would be the route to go. Vivian isnt pushy, but thinks i should probably get flashed to whatever the current strategy because her tunes are set up for it.
In what conditions do you get 20mpg? elevation? flat/hilly? highway/city/mix?
I think i will just keep the old turbo for a little while longer and go with the Barder stage 1 as a replacement.
houli is offline
post #9 of 11 Old 03-29-2014, 04:52 PM
I just noticed you had larger injectors if I were you I would stick with a stock charger so you don't cause your transmission to implode.
My elevation is not a factor it is mainly flat out here and I get 20mpg on the highway, I commute 150 miles a day to and from work. In the city I average 16, I guess I'm a little more aggressive in the city.
I love my tune from bill and I think it works well with atlas 40 or 80 on my truck but every truck is different.
Me personally would rather have the truck running optimal then be concerned with fuel mileage. My truck runs top notch and feels real strong with all the upgrades and regular maintenance.
Strategy should not matter the tuner should be able to write over the pcm.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #10 of 11 Old 03-29-2014, 06:22 PM Thread Starter
I have a manual transmission so I don't think I need to worry about it. When my clutch goes I might get a stronger one though.
I would be thrilled to get 16 in town! I have gotten 11-12. I agree that I want my truck to be running optimally, I think my 12 mpg is telling me that it isn't. We'll see what the turbo does when that time comes. And then maybe a different tune. I appretiate your input, it has been helpful for me figuring out what's going on and what to do.
houli is offline
