No heat! Need help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-24-2014, 07:35 AM Thread Starter
No heat! Need help
I have a 2004 6.0 and my heat only works intermittently while driving. I need some help on where to look next. Here's what I've done so far...
-drained and flushed coolant (several several times)
-new radiator
-new heater core
-new thermostat
-new water pump
After fixing all of those I'm still not getting any heat, so I figured I may have a vacuum line issue, but my air doesn't default to defrost. Blend door actuator is rotating so I know it works... But I'm not sure exactly where I should start next. Any help is greatly appreciated.
KWHolst is offline
post #2 of 8 Old 03-24-2014, 02:24 PM
duck fan's Avatar
Check the heater hoses. There is a vacuum operated shutoff valve inline on one of the heater hoses. Make sure it is seated properly and the line isn't cracked anywhere.
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #3 of 8 Old 03-24-2014, 02:53 PM Thread Starter
I don't have any valve on my heater line, could that be me my problem? The grey vacuum line is just plugged in to a spot on a box that doesn't have a hole in it, it seems like a place holder...
KWHolst is offline
post #4 of 8 Old 03-24-2014, 07:49 PM
duck fan's Avatar
Do you have a picture?
duck fan is offline
post #5 of 8 Old 03-25-2014, 02:33 AM Thread Starter
First pic of where the vacuum line is connected, I believe the picture got turned 90 degrees counterclockwise
KWHolst is offline
post #6 of 8 Old 03-25-2014, 02:36 AM Thread Starter
Second picture of vacuum line unplugged, rotated again
KWHolst is offline
post #7 of 8 Old 03-25-2014, 11:53 AM
duck fan's Avatar
can you get a picture of the heater hoses where they run along the pass valve cover?
duck fan is offline
post #8 of 8 Old 03-26-2014, 10:00 AM
lx_2nv's Avatar
im interested myself - have similar issues!
Tom Brown
2004 Ford SEXcursion Limited 6.0
1991 Ford Mustang LX 5.0
lx_2nv is offline
