Turbo alignment issue - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-23-2014, 08:44 AM Thread Starter
aka MacGyver
rick1067's Avatar
I put a BPD EGR Cooler in, after removing the EGR Delete kit, and can not get the "Y" pipe to align properly. I have used a ratchet strap, long crow bar and sledge and cannot get this thing to align properly. Any suggestions or secrets you know to get this thing aligned?
rick1067 is offline
post #2 of 12 Old 03-23-2014, 08:45 AM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
Loosen the up-pipes at the manifold to give you as much wiggle room as you need.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 12 Old 03-23-2014, 08:48 AM
NYC F-350's Avatar
Quoted: 49 Post(s)
I have also loosened the turbo from the pedestal and lifted the turbo just a little bit to get it to line up...got the clamp on and tightened it just enough to keep the pipe in the flange and lowered the turbo down...then tightened the clamp all the way.
Please
post #4 of 12 Old 03-23-2014, 08:51 AM Thread Starter
aka MacGyver
rick1067's Avatar
I had the Turbo unbolted from the pedestal, and no clamps on anywhere. when the Turbo slides into place on the pedestal, the "Y" pipe is forward by 3/8" and down by 1/4".
rick1067 is offline
post #5 of 12 Old 03-23-2014, 11:05 AM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
Can you get your bolts in on the turbo mount? Sounds like the turbo is not seated all the way down because with turbo mounted the y pipe should line up. Fwiw, my turbo gets caught with sound proofing sometimes causing it not to seat correctly. I would loosen the manifold to where the up pipes bolts up to the manifold and start the bolts to the turbo mount then try hooking up the y pipe after that the down pipe and then tighten the mount bolts. Keep us posted.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #6 of 12 Old 03-23-2014, 11:07 AM
Sometimes you have to walk away for a couple of minutes then come back then everything comes together. Idk why, I just know it works for me.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #7 of 12 Old 03-23-2014, 11:17 AM Thread Starter
aka MacGyver
rick1067's Avatar
LOL I know the feeling. I walked away several times yesterday. Retried it several times, and still cannot get it lined up. I looked at maybe trying to remove the pedestal bolts or maybe the "Y" pipe mounting bolts down by the exhaust manifold.
rick1067 is offline
post #8 of 12 Old 03-23-2014, 11:19 AM Thread Starter
aka MacGyver
rick1067's Avatar
Yes I have all three Turbo mounting bolts in and tight.
rick1067 is offline
post #9 of 12 Old 03-23-2014, 11:21 AM
juniorssrollin's Avatar
Quoted: 2 Post(s)
Loosen the up pipe bolts and you should be able to pull the y-pipe towards you and you will feel it sit in the turbo flange. Tighten the clamp
2005 F350 CCLB FX4
2005 F350 CCLB FX4
juniorssrollin is offline
post #10 of 12 Old 03-23-2014, 07:26 PM
Did you get it aligned?
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
