Oil Cooler ? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-23-2014, 07:02 AM Thread Starter
Oil Cooler ?
I could use some advice ! I have 2005 F250 6.0 with 190,000 miles , it has head studs , EGR delete, EGR cooler deleted. Replaced HP oil pump about 35,000 miles ago, has the 3rd oil cooler since I've owned the truck. I have a scanegauge II to monitor the EOT, ECT, TFT, Voltage. Yesterday towing boat (4500lb) deltas were EOT 197 / ECT 179, this morning took a real long crank to start and deltas ran EOT 192 / ECT 179-181 not towing. I think this points to a 4th oil cooler, but is there any other way to confirm besides deltas ?
Thanks, Mike
towboat is offline
post #2 of 8 Old 03-23-2014, 08:30 AM
SargentoPistola's Avatar
Your ECT seems low which could point to a thermostat. What coolant are you running?
-Kyle-
2004 6.0 Eddie Bauer Excursion. The Man Van.
SCT w/ MPD
Edge CTS w/ EGT Probe
Banks exhaust
EGR Delete
Coolant Filter
Riffraff Boots
Stuff
1999 F-150 XLT 4.6 4x2. The Backup.
SargentoPistola is offline
post #3 of 8 Old 03-23-2014, 09:42 AM
information regurgitator
NYC F-350's Avatar
Quoted: 52 Post(s)
Not only what coolant are you running but how long have you been running it?
Have you flushed the block using chemicals? I ask if you did the flushes and not the garage that did the oil cooler replacements because you would look at them like they had 3 heads if they presented you with that bill. It takes about 8 hours.
The only explanation for going through oil cooler after oil cooler is that the cooling system is contaminated.
Do you run a coolant filter?
Please
You could save the life of a sick child
NYC F-350 is offline
post #4 of 8 Old 03-23-2014, 01:55 PM Thread Starter
Thanks for the responses ! I've been running Rotella coolant, it was replaced the last time by the shop that did my head gaskets and studs a year ago. I'm surethey
towboat is offline
post #5 of 8 Old 03-23-2014, 02:03 PM Thread Starter
Sorry ! I'm sure they didn't flush and I've only done it with distilled water twice since I've owned the truck. I do not have a coolant filter, yet !! Backing up !do my deltas say oil cooler? Is there anyway to confirm that ?
Thanks
towboat is offline
post #6 of 8 Old 03-23-2014, 02:11 PM
NYC F-350's Avatar
Quoted: 52 Post(s)
The ECT is too low, change the thermostat using either a Motorcraft thermostat or, if you run down to the local autoparts store, specify that you want a "fail open" thermostat. Recheck your deltas after replacement.
Keep in mind the 15F delta threshold is when the truck is unloaded. Towing, going up or down hills, or carrying heavy items in the bed will make the EOT higher. Higher engine load will = high EOT.
Please
post #7 of 8 Old 03-23-2014, 02:14 PM
NYC F-350's Avatar
Quoted: 52 Post(s)
Originally Posted by towboat View Post
Thanks for the responses ! I've been running Rotella coolant, it was replaced the last time by the shop that did my head gaskets and studs a year ago. I'm sure they...
Don't be sure....unless they were told to, they probably didn't.
Please
post #8 of 8 Old 03-24-2014, 07:19 AM Thread Starter
I’ve been watching youtube videos on chemical flushing and back flushing the oil cooler and heater core on the 6.0 , looks like something I need to do ! any input? When you back flush the cooler thru the intake where is the water dumping out, the block plug ? I’m hoping to save the oil cooler in my truck without replacing it. Any recommendations on a coolant filter, I’m looking at the Sinister
towboat is offline
