F 250 running hot - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 13 Old 03-22-2014, 10:43 AM Thread Starter
Nate7188's Avatar
Exclamation F 250 running hot
Hi guys,
Ive got a 03' 6.0 F250. It has been bullet-proofed, and has had the FICM, and all new injectors less than 50,xxx miles ago. I recently changed my oil and hit the highway for about a three hour road trip. My EOT was running around 235 and my ECT around 218. Since then ive added coolant to my res to see if that made a difference, but it hasnt that much. Im worried to put this thing back on the interstate with a trip over an hr...what kind of troubleshooting routes should I take? It has never run that hot in the past.
Thanks
Nate7188 is offline
post #2 of 13 Old 03-24-2014, 03:22 PM
Bump for the afternoon / night crew as I am having a similar issue with more of a stock combination.
ShaneOh is offline
post #3 of 13 Old 03-24-2014, 03:48 PM
Ford diesel girl's Avatar
Quoted: 292 Post(s)
Originally Posted by Nate7188 View Post
Hi guys,
Thanks
We need a little more info, but it sounds like it may be a clogged oil cooler (failing).
Give us a more detailed list of your "bulletproofed" mods, and how long ago this started. How fast were you driving, for how long? What was the ambient temp? Were you towing? If so, how heavy?
Your EOT and ECT should be 5-8* from each other. Ford calls a 15* delta, a failed oil cooler (or failing).
Pinky
'04 F350 Pinky truck
I work at some place, in a desert, with a tank...
Originally Posted by Evil Eye View Post
Jeffrey, SHUT IT. I might have to ask Christine to give me a hand in smacking you around a little bit.
Ford diesel girl is offline
The Following User Says Thank You to Ford diesel girl For This Useful Post:
Nate7188 (04-04-2014)
post #4 of 13 Old 04-04-2014, 09:31 AM Thread Starter
Nate7188's Avatar
MODS: ARP headstuds, EGR delete (capped), FICM, AFE cold air intake, SCT Tune (running stock at the time of the issue), new injectors.
This was actually the first time it happened. I have just over 150K on it.
Speed: 65mph
Duration: Got hot at under 1hr of operation at previously mentioned speed. Trip was 3hrs.
Ambient temp: 76 F
Tow: none
Ill look into the oil cooler issue. Any tips for troubleshooting that piece?, or should I just replace the entire cooler?
Nate7188 is offline
post #5 of 13 Old 04-04-2014, 09:42 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
Your oil cooler is junk for sure but you may have another issue. Are you puking coolant and that's why you had to add some? With those temps, I'd suspect a water pump issue like a cracked impeller around the shaft.
dhanna6powerstroke is offline
The Following User Says Thank You to dhanna6powerstroke For This Useful Post:
Nate7188 (04-06-2014)
post #6 of 13 Old 04-06-2014, 08:48 AM Thread Starter
Nate7188's Avatar
So I guess the route im goin to take is to replace the oil cooler with an upgraded one, and since ive only got the cap on the EGR, I should probably upgrade that to the Bullet proofed EGR cooler. Right now, im looking at products on Bulletproofdiesel.com. Does anyone have any recommendations. Im deploying soon and want to do everything necessary once they have most of my engine area torn out.
Nate7188 is offline
post #7 of 13 Old 04-06-2014, 08:50 AM Thread Starter
Nate7188's Avatar
I think I was just low on coolant. Im goin to have the shop do a coolant flush as well when they replace some of the parts.
Nate7188 is offline
post #8 of 13 Old 04-06-2014, 10:04 AM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 331 Post(s)
When she gets hot do you hear the fan come on?
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #9 of 13 Old 04-06-2014, 11:28 AM Thread Starter
Nate7188's Avatar
When it got up to the aforementioned 235, I pulled over, popped the hood and could hear the fan. I cut it off and let it sit for about 20 minutes before I started back up.
Nate7188 is offline
post #10 of 13 Old 04-06-2014, 06:20 PM
you could had a oil cooler issue but first you need to fix the ECT issue then look into the EOT issue if it still exist. A couple things I would look at is a sticking thermostat, clogged radiator (see my spring cleaning Here ). It could also be the water pump as mentioned since a broken impeller that is slipping on the shaft could cause not only high ECT temps but low flow to the oil cooler leading to higher than normal EOT readings.
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
The Following User Says Thank You to U235a4 For This Useful Post:
Nate7188 (04-09-2014)
