2005 F250 No crank/ No Start---but only in the morning - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-22-2014, 04:48 AM Thread Starter
Gents,
First time post. Been lurcking for a while. I hesitate to post, because I'm sure the info I'm looking for is already here just can't find it. So here's what I'm dealing with.....
The truck: 2005 F-250 auto tranny 230k miles. New to me, but very well maintained. Notably, just put in two new Optima Yellow Top batteries and a new alternator.
The Problem:
1. Replaced alternator day before yesterday with O'reilly's standard issue remanufactured alternator. Truck started and ran several times with no problems, belt properly returned to all pulleys, everything seemed fine.
2. Next morning, truck would not crank (i.e., turn over) or start. When key is in on position everything works as it should. When turning the key to the start position, nothing happens--no clicking, no dimming of the dash or interior lights, nothing (I do believe the relays clicked, but that's it).
3. After work, went to begin diagnosing the issue, but when I turned the key, it started right up without hesitation. Drove the truck around all evening with no problems.
4. This morning, went to start the truck and had the same issue as yesterday morning (no crank, no start, no clicking). Weather here in North Texas is mild with an overnight low of around 54 degrees, so it's not terribly cold.
Given the intermittency of the problem, I have no idea where to begin. Oh yeah, truck is not indicating any diagnostic codes.
Please help.
Thanks in advance
rawdeal is offline
post #2 of 2 Old 03-22-2014, 05:30 AM
ps_lane01's Avatar
Quoted: 10 Post(s)
No start sticky!! Read every bit of it! Sounds like a wiring problem. Get a nice auto ranging multimeter.. Check your shifter, put it in neutral, move the steering wheel.... Most of all read the sticky and report here with some actual numbers, otherwise everyone here is 5X as lost as you are.. Welcome to org
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
