Coolant Leaking - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-22-2008, 12:57 PM Thread Starter
sand41's Avatar
Coolant Leaking
From what I have read on this forum I believe it may be the egr but I need some additional input from the pros.
I have a 05 F250 6.0 with 58,000 miles; I just noticed yesterday coolant on the drivers side of the engine compartment. I noticed the coolant from the outside of the truck dripping down from the shock tower; I opened the hood and the whole drivers side under the d gas tank was wet. At first I thought it was a hose but after checking I couldn't find and leaking hoses.
Does this sound like the d gas tank leaking coolant because of the egr or could it be from something else? The truck doesn't smoke and seems to running great.
One more question would the egr be covered under warranty; truck is stock.
Thanks for any help
sand41 is offline
post #2 of 5 Old 11-22-2008, 01:18 PM
Sounds to me like that's your culprit.
2004 F-250, ZF-6, 03 turbo 4" mbrp exh. PHP reprogrammed FICM, sct X3, egr delete, auto meter ultra lite boost & pyro, arp head studs, firestone destination m/t's. ccv mod, mag hytec diff covers, 35% tint, dieselsite coolant filter, cat elc, B&W gooseneck hitch.
screamin7.3 is offline
post #3 of 5 Old 11-22-2008, 05:21 PM
Slacker
Evil Eye's Avatar
Quoted: 223 Post(s)
Feedback Score: 4 reviews
EGR cooler is covered by 100k engine warranty and is your likely problem... Take it to your dealership and describe the symptoms. $100 deductible should get it taken care of.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #4 of 5 Old 11-22-2008, 06:53 PM
Tacomarunner's Avatar
Are those that are paying the $100 deduct, are you guys getting reimbursed?
Russell
O7 F-5504dr 4wd cab and chasis w/ 12' Scelzi service body 6spd manual trans. 200" WB 17,950 GWWR 4.88 gears
Overhead gauges w/ EGT and Boost. FCDP EGR Delete. AEM Workhorse CAI. Down pipe only, no cat or muff.
Tacomarunner is offline
post #5 of 5 Old 11-23-2008, 03:53 AM
Slacker
Evil Eye's Avatar
Quoted: 223 Post(s)
I did for my FICM when it was replaced, but not when my EGR cooler was replaced. It was two separate trips; EGR cooler was a year ago Sept and FICM was this past Sept, so that may be the reason why.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
