Is My FICM Sick? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-19-2014, 07:53 AM Thread Starter
Is My FICM Sick?
I'll start with the symptoms:
-Rough cold start, even when plugged in. It seems to shake and miss for a few seconds and then clears up and idles fine.
-Bad miss until warm. If I try to drive it before temps hit over 100*, it will start to miss real bad at around 1500 rpm's. Even with your foot in it, it's almost impossible to go over 35 mph.
-No codes until a few days ago. Starting last weekend, I am getting intermittent codes. Sometimes a P0306. Sometimes a P0300. Sometimes neither. Sometimes BOTH. (P0306, Cylinder 6 Misfire Detected. P0300, Random Cylinder Misfire Detected.)
-Sometimes I can hear the injectors buzzing real good when I turn the key on. Other times, I can hardly hear them at all.
With everything that I have read, it seems to point to a bad FICM. However, my FICM voltage never drops below 47.5 and usually rides between 48.5 and 49. Battery voltage never seems to drop below 11-11.2 during cranking.
With all that being said, there are some heavy zip-ties that are running around the FICM. It leads me to believe that someone possibly broke the clips off of the plugs.
Is it possible that one of the plugs has loosened up? Would that lead to the symptoms mentioned above?
2006 F350 6.0 CC/LB DRW FX4 Lariat
SCT Livewire TS, Tunes by Nate@WPE
Billet Wheel by KC Turbos
Holders 175/30 Injectors
Sinister EGR Delete
Sinister Coolant Filter
ARP Head Studs
MBRP 4" Turbo-Back, Cat Delete
AirDog FP-150
All Update Parts
mike49107 is offline
post #2 of 10 Old 03-19-2014, 08:06 AM
ZMANN's Avatar
Quoted: 1586 Post(s)
i think you have stiction http://alliantpower.com/sites/allian...01-09r1_en.pdf
plugged in doesn't heat the oil so it wouldn't help the oil fired injectors much being plugged in other than warming up faster
broken connectors are common you can try to fix that first just for peace of mind and you could try a stiction eliminator like hotshots/rev x /archoil
We Miss you Ronnie
ZMANN is offline
post #3 of 10 Old 03-19-2014, 09:05 AM Thread Starter
Two bottles of Rev-X were added at last oil change 3500 miles ago. I haven't noticed any improvement.
I can say that some days (very few) it seems to run great. Other days, not so good.
Sinister EGR Delete
ARP Head Studs
AirDog FP-150
All Update Parts
post #4 of 10 Old 03-19-2014, 09:18 AM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 79 Post(s)
Feedback Score: 7 reviews
What's your ficm power when cranking?
God bless America, the Constitution and the Second Amendment.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
powerstrokeshellback is offline
post #5 of 10 Old 03-19-2014, 09:32 AM Thread Starter
FICM volts when cranking is 47.5-48
Sinister EGR Delete
ARP Head Studs
AirDog FP-150
All Update Parts
post #6 of 10 Old 03-19-2014, 09:36 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
It sure sounds more like injector issues.
The FICM plugs may have been damaged. They usually click in and out nicely, but you have to use the release or it will break the latch. The ties are because of some dummy breaking them, or didn't know how to plug them in.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #7 of 10 Old 03-19-2014, 10:17 AM
Ford diesel girl's Avatar
Quoted: 294 Post(s)
I had these same symptoms, that ended in a hot no-start condition. My FICM read 48-49.5 (BPD beta test FICM), and my ICP was being screwy. IPR was fine. I've got a 2004.
All 8 injectors needed replacing (which ended up being the HPO leak I had). 177k on original injectors, I guess I can't be too mad hahaha. I also replaced my stand pipes, dummy plugs, and ICP. My truck is super happy! Check your ICP as well.
Pinky
'04 F350 Pinky truck
BPD oil cooler system
BPD EGR cooler
BPD FICM
BPD water pump
I work at some place, in a desert, with a tank...
Originally Posted by Evil Eye View Post
Jeffrey, SHUT IT. I might have to ask Christine to give me a hand in smacking you around a little bit.
Ford diesel girl is offline
post #8 of 10 Old 03-19-2014, 10:34 AM Thread Starter
ICP seems fine. I can't recall what it reads at startup. Pressure is around 575-ish at warm idle.
I haven't had any hard start hot issues.
Sinister EGR Delete
ARP Head Studs
AirDog FP-150
All Update Parts
post #9 of 10 Old 03-19-2014, 10:38 AM
Quoted: 294 Post(s)
I am still leaning toward injector issues for you, especially if your FICM is fine. It took awhile for my ICP to crap out on me with those same symptoms you have, just FYI.
Pinky
BPD EGR cooler
BPD FICM
BPD water pump
post #10 of 10 Old 03-19-2014, 10:40 AM
Quoted: 5 Post(s)
Injectors.
05 Extended Cab FX4
SCT w/ Gearhead Tunes
Ble-Blah mod...
Edge Insight CTS w/EGT
PHP Tuned FICM-Hercules
a2elvis is offline
