2004-hard start checklist - Ford Powerstroke Diesel Forum
post #1 of 25 Old 03-19-2014, 01:43 AM Thread Starter
juniorssrollin's Avatar
Quoted: 2 Post(s)
Hey guys,
Starting work on a 2004 built 08/03. 218k and fresh head gaskets. Unsure of any other repairs done on it.
No start hot, let it cool 30 minutes usually starts. Good and strong cold starts. Today while letting off the throttle owner stated it just died, I towed it to my place.
Ficm voltage good/ Sync-yes, new OEM oil cap and filter.
Pictures in order
KOEO
While cranking (truck DID start after cranking more to build HPO)
Last two are at idle
Owner wants to do Dieselsite HPOP if that's the issue, EGR delete, coolant filter, oil cooler, IPR (could be an issue since it just had work done)
and a few more things.
I plan to pressure test the system, pull IPR and then go from there.
Think oil rail nipple o-rings are a possibility?
Just wanted help to ensure I cover all the bases.
Thanks
Dustan
2005 F350 CCLB FX4
ID:	259529   Click image for larger version
ID:	259537   Click image for larger version
ID:	259545   Click image for larger version
2005 F350 CCLB FX4
juniorssrollin is offline
post #2 of 25 Old 03-19-2014, 05:04 AM
aka MacGyver
rick1067's Avatar
Originally Posted by juniorssrollin View Post
Hey guys,
Pictures in order
KOEO
Thanks
Dustan
2005 F350 CCLB FX4
Dustan, If you are going to pull the oil rails to do the nipples and o-rings, I would first look at the Dummy plugs and stem pipes. They are known to be a major fault for the "Cold Start" Issue.
rick1067 is offline
post #3 of 25 Old 03-19-2014, 05:37 PM Thread Starter
Quoted: 2 Post(s)
Rick, with this motor being the early version it does not have dummy plugs or stand pipes like the 2004.5+ motors
2005 F350 CCLB FX4
post #4 of 25 Old 03-20-2014, 05:34 AM Thread Starter
Quoted: 2 Post(s)
Guys why would the ICP pressure be above 20 after a cold soak all night and day?
2005 F350 CCLB FX4
2005 F350 CCLB FX4
post #5 of 25 Old 03-20-2014, 09:50 AM
Ford diesel girl's Avatar
Quoted: 292 Post(s)
Early 2004s (mine is a 10/03) DO have stand pipes. They had never been replaced, and were part of my HPO leak issue.
I had a hot no-start and replaced my stand pipes, along with the ICP, and all 8 injectors.
Pinky
'04 F350 Pinky truck
I work at some place, in a desert, with a tank...
Originally Posted by Evil Eye View Post
Jeffrey, SHUT IT. I might have to ask Christine to give me a hand in smacking you around a little bit.
Ford diesel girl is offline
post #6 of 25 Old 03-20-2014, 10:09 AM Thread Starter
Quoted: 2 Post(s)
Yea your correct, your talking about this style. Haven't heard them to be as problematic as the newer design
2005 F350 CCLB FX4
2005 F350 CCLB FX4
post #7 of 25 Old 03-20-2014, 10:16 AM
Quoted: 292 Post(s)
Yea you're correct, you'retalking about this style. Haven't heard them to be as problematic as the newer design
2005 F350 CCLB FX4
They don't seem to be, but with a HPO leak, you may as well change them anyway, to prevent issues. My techs here at BPD recommended them to be changed on mine. That's just me, though.
Excuse my grammar Nazi-ness. I can't help it!
Pinky
post #8 of 25 Old 03-20-2014, 11:19 AM Thread Starter
Quoted: 2 Post(s)
Haha that's fine, my hands are dirty and was typing quick.
Intake is out and I was surprised to see this intact.
And who the F*** installs a ground wire like that when it has a good eyelet on the end?!?!
2005 F350 CCLB FX4
ID:	260305   Click image for larger version
2005 F350 CCLB FX4
post #9 of 25 Old 03-20-2014, 11:59 AM
4506.0's Avatar
LOL, maybe someone needs there glasses checked.
To answer your ICP question I've noticed many of them have a number higher then zero all the time.
HPOP might be next place to go.
16 F350 CC LB DRW 6.7 FX4
4506.0 is offline
post #10 of 25 Old 03-20-2014, 02:01 PM Thread Starter
Quoted: 2 Post(s)
Already going there...the owner of the truck read the forums and is sparing no expense on this truck
2005 F350 CCLB FX4
2005 F350 CCLB FX4
