Grumble/Vibration in front end- where to look
I have a very low frequency vibration in the front end that goes away when I turn the wheel to the right more than about 15 degrees.
It is most noticeable going 40-55 MPH. The vibration does not stop when I turn left, only when I turn right. I noticed that it goes away while I was on some exit ramps/flyovers. It is consistent, always present, not dependent on RPM of engine. Somewhere in the front axle....Thoughts? |
plus some characters
unit bearings in the hub assembly going bad? jack wheel off the ground and pull top and bottom in and out to see. if you have play, they are bad.
ditto .
sounds like a PITA and $ fix..
I'll try the pulling trick in the AM. (isnt that the same test for ball joints?) assuming thats the problem, how long can I delay the fix? |
don't wait if that is the problem. check local driveline shops. they do the work at a reasonable price.
also it is not too bad to do it yourself.
i'm ok with DIY, just need to know what to be on the lookout for/pictures. I've read the threads that have been under unit bearing, but not a single photo....aside from a dust seal. darn.
Ok its all apart...should the 'inside' of the hub near the axle be greased before reassembly?
Also, what to use on the yellow o-ring? What kind of grease. I dont want a bad interaction. Super easy to take apart and putting back together will be easy too. No explaination needed really. Just need some help with the grease situation. |
I know, the board is kind of dead at the moment.
TTT so I can buy the right grease tonight, I have 30 more minutes.. |
