2005 f350 6.0 hard starting after 12+ hrs of sitting - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-18-2014, 07:31 PM Thread Starter
So my 6.0 has 39,000 miles on it and just in the last 3-4 weeks I've noticed after the truck sits all night, no matter what the temperature outside is, it takes 2 times of about 10-15 seconds of cranking on it before it will start when it finally starts I get a decent plume of white smoke and it runs as smooth as it did when it was new. Then it will start and run like normal throughout the day....even after sitting 8 hrs in the parking lot at work it still starts fine. The batteries had never been replaced and I thought maybe they were draining a bit overnight having an effect on the FICM, since they were so old I replaced them and it didn't help out the hard starting issue...but they were due so oh well I guess. Am going to have it scanned by a diesel tech on Friday but figured I would see if anyone else had any ideas.
The only thing that has been replaced on the truck was the EGR cooler replaced by ford. I know the STC fitting hasn't been updated and plan on putting on the screw in fitting replacement....outside of that stuff I'm not sure what else to look at.
chaseJordan84 is offline
post #2 of 13 Old 03-20-2014, 11:03 AM
4506.0's Avatar
You need a way to look at data. Have any gauges?
16 F350 CC LB DRW 6.7 FX4
4506.0 is offline
post #3 of 13 Old 03-20-2014, 12:00 PM Thread Starter
My father in laws buddy is a diesel specialist and I am hopefully going to be hooking up to his scanner tomorrow...I am suspecting a leak in the high pressure oil system. I know the STC fitting hasn't been updated so I picked one of the kits up at ford and am planning on doing that regardless.
post #4 of 13 Old 03-20-2014, 12:42 PM
4506.0's Avatar
There are some simple things to look at with the scanner. If you are gonna do STC, plan on dummy plugs and stand pipes too. It's as common a failure.
STC really should only cause warm start issues or a complete no start though.
4506.0 is offline
post #5 of 13 Old 03-20-2014, 12:51 PM Thread Starter
I am familiar with the dummy plugs..but not the stand pipes, I'll have to look into that.
post #6 of 13 Old 03-20-2014, 07:56 PM
4506.0's Avatar
Standpipes supply oil to the oil rail, the dummy plugs simple plug the other hole in the rail as the rails fit either side.
4506.0 is offline
The Following User Says Thank You to 4506.0 For This Useful Post:
Bu2je (03-22-2014)
post #7 of 13 Old 03-21-2014, 05:19 AM Thread Starter
Cool thanks....well we'll see what the scanner says today, that should give me a better idea of what's going on.
post #8 of 13 Old 03-21-2014, 10:13 PM
05 should have the updated pipes and plugs, 03 and 04 were the main ones with those issues. I would lean more on the side of cold stiction. My 07 did the same thing till I replaced the injectors. Now ive learned of dome oil additives that help with the issue. Not gonna name a specific one because everyone has there opinions but I've found archoil 9100 and rev x to be the most common ones used. Try YouTube and watch the videos. 30-60 dollars could save you the 1400 I spent.
jstubbs87 is offline
post #9 of 13 Old 03-21-2014, 10:38 PM Thread Starter
Scanner says.......glow plug control module...New module installed and codes cleared...we'll try her out in the morning. I run Rotella T6 synthetic and the truck loves it. Right before I switched to the synthetic my truck started showing signs of injector stiction with rough running after cold start, now it purrs as soon as it fires up no matter how cold it is.
post #10 of 13 Old 03-22-2014, 07:37 AM
4506.0's Avatar
Hmmm, I replaced a lot of plugs and pipes in 05's...
4506.0 is offline
