ficm or injectors? missing and codes - Ford Powerstroke Diesel Forum
 3Likes
  • 2 Post By NYC F-350
  • 1 Post By kinnisoj
post #1 of 8 Old 03-18-2014, 06:41 PM Thread Starter
zipperhead93's Avatar
Send a message via Yahoo to zipperhead93
04 with the headstuds, egr blocked, and 130,000 miles I was having trouble getting the truck to start when it was -23 F out and let it sit until the next week when it was around 25 F. I charged the batteries and replaced the fuel filters and the truck started but has a bad miss so i lert it warm up for 45 minutes and the miss never went away. I pulled the codes and wow here they are: p0265,p0266,p0268,p0273,p0278,p0283,p0336,p0403,p0 405,p0528,p0611,p0677,p1000. My question is can a bad ficm cause the injectors not to fire or do I now have multiple casualties of the cold. I am going to check the ficm voltage this weekend but any insight to what else to look for will be greatly appreciated. Thanks in advance
04 f-250 cc. sb. auto. 3.73 gears
studded and deleted, gauges,Zoodad, idp sct, custom 5" exhaust, 295/85-16 bfg mud terrains, galaxy cb. dvd player, diamond plate tool box, train horns, onboard air, front and rear firestone air bags, 9' western pro plow and a bunch of fire strobes and led lights.
zipperhead93 is offline
post #2 of 8 Old 03-18-2014, 06:43 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
I regret to inform you of the passing of your FICM.
Give Ed a call at FICMrepair.com
zipperhead93 and kinnisoj like this.
Please
You could save the life of a sick child
NYC F-350 is offline
The Following User Says Thank You to NYC F-350 For This Useful Post:
zipperhead93 (03-19-2014)
post #3 of 8 Old 03-18-2014, 06:50 PM Thread Starter
Ok as long as that will cover it I consider myself lucky, I just did not know if the miss was just the ficm or worse. thanks for your quick response.
post #4 of 8 Old 03-18-2014, 07:02 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
A sick ficm can reeley mess with your 6.0. And if you don't make it all better it will reeeeeeley mess with your pocket book.
Curious what oil you are running. I found the Rotella t6 to help a ton with mmy cold weather start up.
zipperhead93 likes this.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
The Following User Says Thank You to kinnisoj For This Useful Post:
post #5 of 8 Old 03-18-2014, 07:30 PM Thread Starter
rotella 15-40 but thinking of going to lighter oil in the winter now that I am reading all the threads on here.
post #6 of 8 Old 03-18-2014, 07:53 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
When you get your ficm fixed you might try the rotella t6 with a shot of the Archoil or Rev x. I was very happy with how much it helped out.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 8 Old 03-19-2014, 07:22 PM Thread Starter
called Ed at ficmrepair and its on its way along with the atlas 40 tune. I also went for the oil and fuel additive along with the blue spring kit. Thanks guys you helped out greatly.
post #8 of 8 Old 03-21-2014, 06:44 PM Thread Starter
Happy Happy Happy
Thank you Ed from ficmrepair.com I installed the rebuilt ficm and the truck started right up with no missing or roughness what so ever. You did a great job from the initial phone call, to the order process and was delivered right on time. The help from NYC 350 was greatly appreciated to point me in your direction. You all saved me a lot of headaches and dollars at the dealership.
