Missing,smoke, then wont stop cranking?! - Ford Powerstroke Diesel Forum
post #1 of 26 Old 03-18-2014, 01:04 AM Thread Starter
06 power stroke with auto trans. We drove it a bunch of miles over the weekend. Yesterday my girlfriend went to take the truck and told me it that it started up kinda rough so she shut it off. I get home and took a look. Started up and it was missing real bad and smoking blue,grey smoke pretty bad. I got it backed up out of the way. Check the ficm and things with the CTS. All looked good. Tried starting again and wouldn't start this time. Let off the key and its still cranking. Took the key out and ran in the garage to get a wrench to unhook the batteeys
Its still cranking at this point. Almost killed the battery's by the time I got them unhooked. What could these problems be? About 4-5 months ago just had new heads,studs,gaskets, warren injectors,03 billet wheel turbo blue spring done. About a year ago did egr delete and oil cooler. Any ideas? This thing is crazy! Thanks for any help.
JIMS SVT is offline
post #2 of 26 Old 03-18-2014, 04:13 PM Thread Starter
Got the starter to stop cranking by tapping on it. Still no clue on the other part. Maybe a bad injector or two?
JIMS SVT is offline
post #3 of 26 Old 03-18-2014, 07:34 PM
ps_lane01's Avatar
Quoted: 10 Post(s)
No codes? What does its vitals show when cranking? Icp, ipr, ficm, hfcm power, etc?
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #4 of 26 Old 03-18-2014, 11:55 PM Thread Starter
No codes with the cts or sct. ficm is 47.9-49.5v. Didnt get the check much more since the starter wouldnt shut off. Since I got that to stop I havent crancked on it anymore.
JIMS SVT is offline
post #5 of 26 Old 03-19-2014, 05:17 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
For the starter, your solenoid is probably fried. Based on the excessive cranking, you probably need to replace the whole starter.
Your other problem reads like injector issues. One big failure open, or 2 that are partially sticking open.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #6 of 26 Old 03-19-2014, 07:41 AM Thread Starter
I hope so. Just had warren do these 175's a couple months ago. Its just strange it happened over night. I'm gonna replace the starter.
JIMS SVT is offline
post #7 of 26 Old 03-20-2014, 04:41 PM Thread Starter
Truck seems to be charging at around 12.0-12.4 volts at idle when I get it started but smokes bad and has a bad miss. Ficm voltage looks good at 47.5-49v. ICPv 1.4ish. Could it be a charging issue?
JIMS SVT is offline
post #8 of 26 Old 03-20-2014, 05:30 PM
Quoted: 47 Post(s)
If after 2 minutes it doesn't get above 13.4v, check it with another meter that is calibrated. Being that FICM v is good, a charging issue is not the cause of the roughness.
Frank
Working for Toys
post #9 of 26 Old 03-20-2014, 05:43 PM Thread Starter
I doubt it would even run for two minutes honstly. Cant hardley get it to take any throttle. What else should I check for?
JIMS SVT is offline
post #10 of 26 Old 03-20-2014, 05:43 PM
E99F350Stroker's Avatar
IMHO I would highly advise for you to get a diagnostic scanner of some kind if you don't have one. I recently bought an auto enginuity scanner and it paid for itself the first time I used it. If I had gotten one sooner I would have saved myself even more money because I actually would have had trouble shooting capability with the scanner as opposed to just throwing parts at it. There is only so much that you can do without one.
edit: I just saw that you have a CTS but I am not familiar with them. Does it have the ability to monitor the ipr duty cycle and icp pressure?
Jordan
*Sold* Early 99 F-350 dually 4x4 6spd 7.3
*Sold 2000 F-250 4x4 ATS auto 7.3
1996 Dodge 2500 4x4 speed, 12 valve cummins, 283000, stock
E99F350Stroker is offline
