My horn honks when i turn on or off car whith lights on - Ford Powerstroke Diesel Forum
post #1 of 18 Old 03-17-2014, 07:04 PM Thread Starter
hey all, I have 04 f350 and the previous owner apparently used the truck as a work truck up and Alaska, so if I have the head lights on and put the key in the ignition the horn honks continuously but if I start the truck first then turn the head lights on it wont honk(but the horn works). Now if I turn the truck off with the headlights on it will honk continuously until I turn the lights off. Also the cruise control doesn't work but if I try to set it it will honk. the truck use to have work/strobe lights hook up but was all removed.
How do I fix this??? I hate not being able to have the headlights on with out starting the truck
Thanks guys!
PNW6.0 is offline
post #2 of 18 Old 03-18-2014, 03:22 AM
aka MacGyver
rick1067's Avatar
Thanks guys!
What a wiring nightmare. Do you know if the wiring for the strobe lights was into one of the upfitter switches?
rick1067 is offline
post #3 of 18 Old 03-18-2014, 03:25 AM Thread Starter
It had after market switches along with a sepate fuse panel, I followed all wires and removed them cleanly, noting was hooked into the truck harness
PNW6.0 is offline
post #4 of 18 Old 03-18-2014, 04:01 AM
aka MacGyver
rick1067's Avatar
I am looking through the wiring schematics to find you an answer
rick1067 is offline
post #5 of 18 Old 03-18-2014, 04:03 AM Thread Starter
Thank you!
PNW6.0 is offline
post #6 of 18 Old 03-18-2014, 05:29 AM
aka MacGyver
rick1067's Avatar
Thank you!
Does your vehicle have auto lamps?
rick1067 is offline
post #7 of 18 Old 03-18-2014, 06:45 AM
aka MacGyver
rick1067's Avatar
Looking through the schematics, the only place where I find either of the two positive wires in close proximity is in connector C270h on the back of the CJB (Fuse box) See Pic below. Looking at the ground wires, the horn and headlights are on the same wire. Your horn relay is activated when you depress the horn pad. It seems to me that the ground from your horn may either be broken, corroded or loose causing the contact in the circuit to work intermittently. This being said, this would cause the horn to use the ground from your headlights which in turn would activate the horn when the lights are turned on.
rick1067 is offline
post #8 of 18 Old 03-18-2014, 06:49 AM
ZMANN's Avatar
Quoted: 1781 Post(s)
the strange part is the way he can manipulate the problem by turning headlights on or off before the ignition
We Miss you Ronnie
ZMANN is offline
post #9 of 18 Old 03-18-2014, 06:52 AM
aka MacGyver
rick1067's Avatar
You should be able to turn the headlights on without the key even in the truck. This would be why the bell dings when you take your key out and the headlights are left on.
rick1067 is offline
post #10 of 18 Old 03-18-2014, 09:37 AM Thread Starter
Ok I will look into the ground, but its almost like some wired the horn insted of the ding noise when you leave lights on, thanks
PNW6.0 is offline
