Where is my Oil leaking from??? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-17-2014, 01:39 PM Thread Starter
Ok I have an 03 F250 6.0. It started to leak oil like crazy, If it runs for like 5 minutes it dumps out a good 1 1/2-2 quarts of oil and I can't see where it is leaking from. I know that oil was all over the turbo and the rear of the motor. And its not leaking from the inlet oil line on the turbo or anywhere else that can be seen. I took the turbo off and there is a lot of oil on the rear valley of the motor. So Im guessing that its either leaking from the turbo return line or the icp sensor. How do I find out? Is it ok to block off the turbo inlet oil line and crank the motor to see? Or what? Any suggestions on how to find out what it is and how to do it??
mudderman is offline
post #2 of 3 Old 03-17-2014, 02:36 PM
the 03's blow out the icp sensors a lot, and cause bad oil leaks. If the truck was running and you are under it on the drivers side, look up at the pump cover. You'll prolly see oil dripping off of that silver insulator.
oh yeah, if the stock heat shield is there, it would be hard to see, for sure
Scumbag is offline
post #3 of 3 Old 03-18-2014, 07:47 PM
ps_lane01's Avatar
Quoted: 10 Post(s)
Hpop cover gasket? Turbo return?
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
