intermittent no/delayed start - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-16-2014, 05:17 PM Thread Starter
So I have an interesting one start happening in the past week. In each instance my truck is cold as in sitting overnight. When I go out to turn on my truck, I turn the key to on and wait for the glow plugs to go out, than I try to turn on the truck and nothing happens, no crank, no clicking, just silence. All the lights and electrical stuff work and I know my batteries are good so it cant be them. So I cycled the key again, and left them in the on position, waited 30 seconds to a minute and than tried again, it cranked and fired right up. Any ideas why I have to leave the keys in "on" for longer than the glow plugs indicate?
2003 F250 SuperDuty 6.0
and.decarlo is offline
post #2 of 2 Old 03-16-2014, 07:38 PM
x148's Avatar
I would use a volt meter and test on the signal wire (starter) to see if it's getting power while you crank and go from there
05 F350
-Sinister EGR Delete
-Banks High Ram
-Blue Spring
-Air Dog II
-K&N Intake
-H&S Mini Max
-Swamps 58v FICM
-03 Turbo
-5" MBRP turbo back
-ARP Head Studs
-Cat ELC1 Coolant
-6" Lift on 37" Toyo M/T
-Detriot True-Trac with 4.56 Gears
-Pro Comp Trac Bars
x148 is offline
