Power steering whine/hard steering - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-16-2014, 12:00 PM Thread Starter
Hey guys I'm looking for a little advice. I've got a 2007 f-250 6.0 4x4 mostly stock with stock tires and about 107k on it. I was driving out on a dirt road by my house after it rained real hard and slid into the ditch with both passenger side wheels and had to do a lot of back and forth in 4 low with the hubs locked and a lot of turning the wheels to get out, I think it might have messed up my psp cuz now it's whinning and when I turn right w/o giving any gas it won't barely turn the wheels at all. So my question is do y'all think I need to replace the pump or would a fluid flush possibly fix it? Thanks, Michael.
michael324 is offline
post #2 of 10 Old 03-16-2014, 01:06 PM
Quoted: 818 Post(s)
Is the reservoir full?
Corey@CNCFAB is offline
post #3 of 10 Old 03-16-2014, 01:42 PM Thread Starter
Just checked it and it's actually about an inch lower than the dipstick so I need to put some in for sure. I don't know how long it's been like this but I had an oil change and fluid check about 3 months back so it might be recent. I haven't noticed any leaks while parked but I have a dirt driveway so it might not have showed up. Do you think adding fluid will help or do you think there's a bigger issue?
post #4 of 10 Old 03-16-2014, 01:56 PM
Quoted: 818 Post(s)
You could've tweaked the return hose on the bottom when you went off the road and lost the fluid then. I'd try a flush first.
Great youtube vid by Trey Spooner on how to do it.
post #5 of 10 Old 03-16-2014, 01:57 PM Thread Starter
The fluid kinda smelled bad too so I'm pretty sure I should do a flush but I'm just a little worried cuz I had no steering problems at all until I went in the ditch...
post #6 of 10 Old 03-16-2014, 02:10 PM Thread Starter
Ok thank you so much I'll try the flush probably won't get to it till this weekend but I'll post the results.
The Following User Says Thank You to michael324 For This Useful Post:
Corey@CNCFAB (03-16-2014)
post #7 of 10 Old 03-17-2014, 07:38 PM Thread Starter
So I did the flush and the problem is still there. It turns fine when I give it throttle but at a stand still it will barely turn at all. The power steering box is still whining and I also noticed that it whines louder when I press the break pedal and the pedal feels kind of like it pulses a little when pressed but the breaks still work fine.
post #8 of 10 Old 03-18-2014, 05:24 AM
Quoted: 818 Post(s)
Originally Posted by [url
https://m.facebook.com/profile.php?id=649810805061097[/url] ]The fluid kinda https://m.facebook.com/profile.php? https://m.facebook.com/profile.php?id=649810805061097 =649810805061097 bad too so I'm pretty sure I should do a flush but I'm just a little worried cuz I had no steering problems at all until I went in the ditch...
post #9 of 10 Old 03-18-2014, 06:36 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
More than likely you burned the pump.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #10 of 10 Old 03-18-2014, 06:46 AM Thread Starter
Yea I'm gonna buy a new pump and I'm gonna tackle that problem first. Would the pump problem alone cause the steering to be harder to turn right than left though? I'm just a little worried that the pump might not be the only problem..
