4X4 Locking Hub - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-13-2014, 05:39 PM Thread Starter
4X4 Locking Hub
Just did ball joints on my 2003 F250 4X4. All complete but I cant get my locking hub back on the axel shaft. No matter how many times I rotate it just wont slide in?????
Bubbalarge
Bubbalarge is offline
post #2 of 3 Old 03-14-2014, 08:08 AM
aka MacGyver
rick1067's Avatar
Bubbalarge
Although I have never replaced a Locking hub yet, Here is a good vid on the issue. Looks like a good wire brushing to remove the rust from the parts as well as air pressure to get the dust out. Just to make sure that is not causing the fit problem. After that I would use some grease to help it slide in.
I do not see any major "Key Ways" on this one but make sure those are aligned if you have them on your parts.
If still no joy, as you rotate the locking hub, you should feel it kind of drop into place in the axel shaft. I would take a rubber mallet and see if you cannot nudge it back into the shaft.
rick1067 is offline
The Following User Says Thank You to rick1067 For This Useful Post:
1ATony (04-14-2014)
post #3 of 3 Old 03-14-2014, 08:31 AM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 350 Post(s)
Sometimes you have to use a bar and wiggle the 4x4 shaft to center it. Then it should slide right.
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
