zero power after hg.. please help - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-13-2014, 11:19 AM Thread Starter
Truck starts good idles good but has no power. Wont power brake over 1000rpm. No codes. Did hg egr delete studs powermax and afe intake. Has 60psi of fuel pressure. Is full of oil. Ficm has propper voltage. When i take it down the road it will eventually get going and build boost but doesnt have the powerit should. Checked all intercooler boots unplugged icp checked ebp please help....also no smoke
truckguy876 is offline
post #2 of 13 Old 03-13-2014, 12:09 PM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
You shouldn't get smoke.
Try sticking your foot over the exhaust pipe and listen under the truck and under the hood. Suspect a pre-turbo exhaust leak.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 13 Old 03-13-2014, 12:11 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
I have no clue what you are trying to convey.
Was anything else changed besides the HGs? The fact that it has no smoke is somewhat interesting in that it means you have either the right amount of fuel for the air, or not enough fuel. Most of the typical exhaust and boost leaks would be somewhat smokey while accelerating. The Powermax with stock injectors and no tune usually produces disappointing results with the slow to build boost symptoms you describe. It would smoke with a power tune. So you checked the values, what were they?
At Idle: ICP, IPR, EBP, Boost, VGT, Fuel Pressure and EGT
While accelerating with 14-50% pedal the same. Also add PW (pulse width). Note RPM when boost builds faster.
While accelerating at WOT, all of the above. What is your max boost? How does the truck shift?
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 13 Old 03-13-2014, 02:18 PM Thread Starter
The truck builds 20 pounds of boost but is much slower then before. I have the scan guage and have to put more of the xguage codes in. Icp is reading 53 at idle and 110 wot. There is a very little smoke and i have an atlas 50 tune on the ficm. All connections checked multiple times. Fuel pressure holds steady at 60 psi. The pm intake hg and egr delete was all done at the same time. In park it revs slow and has a noticable miss. Ill put the codes in on the scanguage now and get you the other readings..thank you for helping me
post #5 of 13 Old 03-13-2014, 02:48 PM Thread Starter
Icp 37 ipr 21.8 eb 17.5 vgt 71
post #6 of 13 Old 03-13-2014, 03:57 PM
Quoted: 47 Post(s)
In park it revs slow and has a noticeable miss.
As you know, it should rev very quickly in Park, even with an injector not working. With more than one dead, that could give you your symptoms.
If these are Idle Parameters, the EBP is atmospheric and the IPR and VGT look OK. Boost would be about 0.3 psi. The ICP needs a better PID selection to read correctly. It should be about 600-800 psi or 0.9-1.2v depending on the temperature and idle RPM.
Ensure all the injectors are connected and the FICM plugs are clicked in to position (yes, check them again). All codes, if any would help. Are you absolutely sure that nothing dropped into the engine, heads or HPO system? You may need to pull the IPR to check the screen. Even though it idles, it may be sticking at a lower position than commanded. Same goes for the injectors and other parts, are you absolutely sure you installed parts correctly?
When you get some better ICP numbers, it may help track down the problem.
Frank
Working for Toys
post #7 of 13 Old 03-13-2014, 04:10 PM Thread Starter
Truck is now dropping oil pressure at idle. Afterrunning it i let it idle and pressure on dazh guage goes to 0. Raise rpm and it reads normal.i checked all plugs and connectors at least 10 times. Im positive it was reassembled correctly and took every precaution i could to make sure nothing fell in the motor
post #8 of 13 Old 03-13-2014, 04:30 PM Thread Starter
Whats the max i can have milled off the heads? The machine shop said they were gonna cut like .008 off even though the heads were .004 out. I was told thiscould be part of my problem
post #9 of 13 Old 03-13-2014, 05:41 PM
Quoted: 47 Post(s)
You could be OK, but you need to ensure valve clearance as you are at the limit.
Your low pressure oil issue could be a red herring, but if your ICP is way off lower than expected and the IPR is going higher, you could have a low pressure pump issue. However, remember the low pressure gauge is not a gauge, it is a 7 psi switch. If your pressure was that low, the engine would probably not run or would run poorly.
Frank
Working for Toys
post #10 of 13 Old 03-14-2014, 03:35 PM Thread Starter
Icp is 700 at idle ipr duty cycle is 24 truck has zero power... did the bubble test on the injectors. No air coming up in fuel bowl. Fuel still steady at 60psi. Sat all night and started fine. Still revs slow...anyother ideas... should i pull all the push rods?
