Loud hissing and no boost - Ford Powerstroke Diesel Forum
post #1 of 28 Old 03-12-2014, 07:28 PM Thread Starter
I have an 05 6.0 powerstroke and recently I started to get a loud hissing and no boost untill I drove it for a few minutes and then the hissing would go away and it would start building boost again....now it does it everytime I try to drive it whether its cold or has been running and warm..plugged my sct in and checked for codes..it showed P0069, P0113, P0470, P0528...
Malakas is offline
post #2 of 28 Old 03-12-2014, 07:29 PM Thread Starter
Originally Posted by Malakas View Post
I have an 05 6.0 powerstroke and recently I started to get a loud hissing and no boost untill I drove it for a few minutes and then the hissing would go away and it would start building boost again....now it does it everytime I try to drive it whether its cold or has been running and warm..plugged my sct in and checked for codes..it showed P0069, P0113, P0470, P0528, P2199
Malakas is offline
post #3 of 28 Old 03-12-2014, 08:38 PM
You have an air leak somewhere in the charge air side, could be a hot side rubber boot, cracked intercooler, or loose clamp somewhere. It would explain all those codes except the fan speed sensor code(P0528). For that, check the connector on your fan shroud for condition and proper installation.
Bodywerks0660 is offline
post #4 of 28 Old 03-12-2014, 11:42 PM
Quoted: 2 Post(s)
Check the rubber boot (the one with a slight bend in it) going from the turbo to the hot side pipe. It tends to flex and split over the years. If its coated in oil, it's probably history.
---Garret
2006 F250 6.0 XLT FX4 CCSB
S&B Intake
MBRP 4" straight pipe with 5" tip
Studded and deleted
CTS w/EGT
Atlas 40 and Looney Tuned
2002 F250 7.3 XL Reg Cab 2wd Sold!
1995 Ram 3500 Dually Reg cab 5.9 12v auto 2wd
Fordtrucktexan is offline
post #5 of 28 Old 03-13-2014, 06:15 AM Thread Starter
What throws me off os that I dont have any leaks..all my boots look good..its a very loud hisssing almost like my exhaust gets blocked off...boost gauge doesnt move and then all of a sudden everything is fine again
Malakas is offline
post #6 of 28 Old 03-13-2014, 08:06 AM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
What throws me off is that I don't have any leaks..all my boots look good..its a very loud hissing almost like my exhaust gets blocked off...boost gauge doesn't move and then all of a sudden everything is fine again
There is only one way to inspect those boots and that is to remove them. Of course they will "look good" because what you see is not where they fail. They fail on the underside. If the boot has dirt stuck to it, it is suspect. The reason why is that the CCV is connected to the air inlet tube just prior to the turbo (introducing oil vapors to air inlet). That boot is made of silicone, and silicone breaks down in the presence of oil. The oil will make the boot porous and push its way through the boot. That dirt you see on the outside of the boot is actually oil that has made its way through the boot and road grime sticks to the oil.
If the boots are dirty on the outside, it is best to replace them.
To check for exhaust problem, have a friend stick his foot over the exhaust pipe. If it is exhaust related, you will hear it that way. If the noise comes from under the hood, lay down under the truck while your pal has his foot over the exhaust. Using a long stick with a thin strip of paper taped to the end of it, move the stick around the up-pipes (especially the flex joints). Also check the firewall for soot stains.
If you, or someone else, has removed the turbo recently, suspect that they Y-pipe is not properly seated into the turbo inlet flange.
Please
You could save the life of a sick child
NYC F-350 is offline
post #7 of 28 Old 03-13-2014, 08:20 AM Thread Starter
Turbo was removed last summer and the problem just recently started..also sometimes when the truck is idiling I barely get exhaust coming out of the tailpipe
Malakas is offline
post #8 of 28 Old 03-13-2014, 12:42 PM
mrenn's Avatar
Quoted: 3 Post(s)
NYC is right, the flex pipes do have a tendency to crack over time.(bout 165.00 at ford)I had the same noise a while back and the clamp to the downpipe wasnt tight enough so I tightened her up and it was all good.
ARP,EGR Delete,SCT,4.56 gears,powermax,Banks Techni-cooler,Adrenalin HPOP,Donohoe springs,fox shocks,airbags,blue spring,38x15.5 M. Thompson's,4 10's,2 tv's,playstation,amp-steps,2013 tailgate,edge cts
2016 Lariat 6.7.
mrenn is offline
post #9 of 28 Old 03-13-2014, 04:01 PM Thread Starter
Understood..but did the hissing go away after driving for a few minutes each time and were u building boost again?
Malakas is offline
post #10 of 28 Old 03-13-2014, 04:02 PM Thread Starter
Lately it has been doing it after cold starts
Malakas is offline
