2006 no crank no start - Ford Powerstroke Diesel Forum
post #1 of 17 Old 03-09-2014, 06:43 AM Thread Starter
i was jumping starting a buddies car and my truck just randomly shut off now it wont crank,
truck is pretty much stock has intake egr delete and exhaust, NO programmer
-ive checked all the fuses and there all good, also batteries are good
-also tried to pull the codes and it wont read the codes, comes up saying that it couldnt make a connection
- with the key on and in park it says check gauges, has abs light and wrench on
- when i switch it to neutral abs and wrench stay on but it says tbc failure now
- after i turn the key off it displays (-------) that instead of the mileage
- ficm is good
- i pulled the wire on the passenger side for the starter and connected it to the battery and it cranks that way
what else can i check? im lost and cant find anything to help me out, ive searched and havent came up with much
also recently had the code for the transmission range sensor come up but after i cleared the code hadnt had any problem with that since, drove for about two weeks after that came up, could that be the problem?
thanks
duggywuggy08 is offline
post #2 of 17 Old 03-09-2014, 06:45 AM
shenanigans
junior125's Avatar
Quoted: 1615 Post(s)
Garage
pull the connector on the ICP on the valve cover and see if it will start, it sounds like you have a bad Snap to Connect fitting on the high pressure oil pump
Mike
2005 CCSB F250 4X4
junior125 is online now
post #3 of 17 Old 03-09-2014, 06:55 AM Thread Starter
wont get a chance to work on the truck again until monday afternoon but ill try that.
post #4 of 17 Old 03-09-2014, 06:57 AM
shenanigans
junior125's Avatar
Garage
do you have a monitor on it at all? if you can watch what your IPR percentage is it is a good way to see if it is in your HPOP system as well
Mike
2005 CCSB F250 4X4
post #5 of 17 Old 03-09-2014, 07:02 AM Thread Starter
i have a scangauge on it, but it says it wont connect, which is also why i cant check for codes
post #6 of 17 Old 03-09-2014, 07:16 AM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
Sounds like a fried computer to me.
Please
You could save the life of a sick child
NYC F-350 is offline
post #7 of 17 Old 03-09-2014, 07:39 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
Or perhaps a PCM fuse. Jump starting a vehicle improperly can definitely kill a PCM.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #8 of 17 Old 03-09-2014, 08:56 AM Thread Starter
anyway to check the pcm?
post #9 of 17 Old 03-09-2014, 11:40 AM
Quoted: 47 Post(s)
Since you are now getting no communication, you have to ensure it has power to it. If you have power to the unit and no comms, a quick swap-out with a working one would be in order.
Frank
Working for Toys
post #10 of 17 Old 03-09-2014, 03:23 PM Thread Starter
When swapping the pcm does it need to be from the same exact year truck? And there's no programming or anything ford needs to do to get it to start is there?
