6.0 powermax blown seal??? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-07-2014, 02:35 PM Thread Starter
smount101's Avatar
Just put a powermax and 4" straight mbrp on the 2006 6.0. Truck was blowing blue smoke before I swapped. Pulled out the turbo and had about an eighth inch of burnt oil caked on the outlet and down pipe. Bought a powermax put it on along with 4" mbrp. 50 miles later she smokin blue like crazy at stoplight and I can take my finger and wipe the oil out of the exhaust tip. I'm not running any crazy tunes just a mid level tune from Eric @ innovative. Has anyone else had this much trouble with seals or could there be something else causing the oil???
smount101 is offline
post #2 of 4 Old 03-07-2014, 02:54 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
I think you need to determine if the oil is coming from your motor or not. I find it hard to believe that you blew a seal that quick on a new turbo. I would disconnect the up pipe and the down pipe then look for oil residue going into your exhaust manifold. Did you pull the codes? Maybe an injector issue or hgs. A blown head gasket will smoke and the coolant will come out like soot (oily residue). Do you use any coolant or have you checked the pressure of your coolant system?
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #3 of 4 Old 03-07-2014, 03:16 PM Thread Starter
smount101's Avatar
no codes being thrown . no coolant loss. haven't pulled the up pipe since the new turbo install. when I pulled the old one the pipe was a little black but dry. not oily like the downpipe side
post #4 of 4 Old 03-07-2014, 03:46 PM
Got me. Another blown seal I guess then but why? Idk? Either way the turbo is got to come off,good luck and keep us posted.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
