Load Clicking Noise coming from under glovebox area - HELP! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-06-2014, 09:32 AM Thread Starter
Pathfinder22's Avatar
Quoted: 2 Post(s)
Garage
Out of the blue the other day, a loud clicking noise starting. It is 3 short, loud clicks followed by a 1 second pause, then 3 short, loud clicks. It is contact and repeats while the key is in and ignition switch turned before starting motor and/or when the motor is on.
Click this link to hear the noise in question: http://youtu.be/A_hzRlx7dJc
This is driving me nutz -- help!!
FYI - A/C was recently serviced and truck is serviced regularly by a local diesel specialist, with the most recent being oil service, fuel filters and rear brakes.
'06 F350 Lariat CC DRW 6.0L PSD
Fully bullet-proofed including Sinister Coolant Filtration System. Train Horn, Killer Tunes and Re-upolstered seats...otherwise she's all stock!!
Pathfinder22 is offline
post #2 of 6 Old 03-06-2014, 02:37 PM
duck fan's Avatar
Try changing the fan speed on your HVAC and see if that changes the noise. With the rhythm you have going there it sounds like something is either in the fan, or the fan motor is going bad.
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #3 of 6 Old 03-07-2014, 06:40 AM
aka MacGyver
rick1067's Avatar
Click this link to hear the noise in question: What is this Clicking Noise - YouTube
Peter is on the right track. If you turn the Key on, Engine running or not, turn your fan off and do not hear any more noise, it is probably either be the Blower motor or the Fan Blade.
My daughter had the same issue with her car and when I took the motor out, a mouse had crawled into the fan cage and his tail was hitting the inside on the heater box.
rick1067 is offline
post #4 of 6 Old 03-12-2014, 07:57 PM Thread Starter
Quoted: 2 Post(s)
Garage
Thanks guyz. However, the issue is happening without the a/c or fan motor on as well.
post #5 of 6 Old 03-12-2014, 09:53 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
It is probably the diverter that is stuck.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #6 of 6 Old 03-13-2014, 08:08 AM
Im having the same issue, first instinct was something the blower motor. Think I have it narrowed down th the diverter for fresh or recirculating air. Is your vaccum pump running longer than normal?
jstubbs87 is offline
