HELP turbo cleaning! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-05-2014, 05:17 PM Thread Starter
mxrider777's Avatar
I forgot to draw lines on the turbo to align the compressor housing and the exhaust side when reassembling, what do i do know?
doh
2003 F250 CCSB 6.0l
12' lift
43" Michelin xls
sinister coolant filter
zerex elc coolant
edge insight
Egr Delete w/ coolant reroute
mxrider777 is offline
post #2 of 6 Old 03-05-2014, 05:33 PM
I did the same thing on mine, only it was my cleaner that took what was suppose to be a "sharpie." What I end up doing was continually turning the unsion ring and moving the vanes until I got both side to line up. I actually had to stop drinking a few ****tails and walk away about 5 times. Fortunately, I took a picture beforehand so I had at least something to go off of. It only fits one way, I just resorted to the scientific movement of the unison ring and vane position along with the solenoid until it lined up. Probably not the most helpful response, but it worked for me.
rhillman75 is offline
The Following User Says Thank You to rhillman75 For This Useful Post:
mxrider777 (03-06-2014)
post #3 of 6 Old 03-06-2014, 04:36 AM Thread Starter
mxrider777's Avatar
Thanks ive been looking at pictures and doing the same thing you did
2003 F250 CCSB 6.0l
12' lift
43" Michelin xls
zerex elc coolant
edge insight
post #4 of 6 Old 03-08-2014, 08:12 PM
1fastsvt0816's Avatar
Quoted: 9 Post(s)
Here is a pic of my powermax when I marked it to separate it. Should look the same as the stock turbo if this helps
1fastsvt0816 is offline
The Following User Says Thank You to 1fastsvt0816 For This Useful Post:
mxrider777 (03-09-2014)
post #5 of 6 Old 03-08-2014, 08:14 PM
Quoted: 9 Post(s)
Here's another one if this helps too
post #6 of 6 Old 03-09-2014, 10:24 AM Thread Starter
mxrider777's Avatar
Thank you helps a bunch, when i went to torque it down today the clamp snapped
2003 F250 CCSB 6.0l
12' lift
43" Michelin xls
zerex elc coolant
edge insight
