beating my head against the wall - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-05-2014, 05:11 PM Thread Starter
Ok so heres whats going on i had a airdog 2 and was only getting 22 psi at the driven diesel fuel pressure regulator after dealing with them and getting no result and no answers i decided to go with the fass 220gph pump and maybe i will be able to get up to the recommended 60 psi well it went up but only to 40 psi now performance went up alot but i still cant get it to 60 and i am still white smoking what should i do next my mechanics cant figure it out and i just want it to be a good running truck again i basically just have everything that you can to the heads stage 1 injectors, cam, powermax, ported heads, oversized valves zmax intake banks intercooler, its running ok but not perfect and was wondering if anyone knew what i can do i just ordered the upgraded spring for the fass but other then that i dont know what to do we have opened up the regulator and tried turning it up and down and see no change at all i have no clue what else to do
alchigh150 is offline
post #2 of 6 Old 03-07-2014, 12:58 PM Thread Starter
any suggestions would help maybe from a mechanic or something there is no way that im the only one with this problem
post #3 of 6 Old 03-07-2014, 02:02 PM
Teachagmech's Avatar
Quoted: 408 Post(s)
Garage
have you checked the fuel pickup in the tank? if you can't get adequate fuel pressure from an aftermarket pump, then you've got something else going on. The pumps may have longevity issues, but you'd think that out of the box, they would be able to supply plenty of pressure. Makes me think its a suction side problem
Mike"Bustin' mine to feed yours"
The "Kerosene Queen"
2005 F-250 CCSB FX4 LARIAT 150K blue spring, coolant filter, DC Power alt. and
Teachagmech is offline
post #4 of 6 Old 03-07-2014, 02:33 PM Thread Starter
yes thats another thing when i went to the fass 220 i went and installed the fass sump kit to remover that as an option as well and to eliminate the 1/4 tank issues
post #5 of 6 Old 03-07-2014, 04:04 PM
Quoted: 816 Post(s)
Sell the pump to a cummins guy a put the stock pump back in or buy an A1000 or fuel lab prodigy.
Corey@CNCFAB is offline
post #6 of 6 Old 03-18-2014, 05:34 AM
Quoted: 408 Post(s)
Garage
I can't see what year truck the OP has, but this thread may she'd some light if you haven't found the problem
blue spring mod...no change?
Sent from one of the worst apps in the world
Tags
fuel , low pressure , starving
