P1000 code?
after taking my truck in to ford to get the latest flash it no longer blows smoke even with my programmer on performance. i pulled the codes and i got a P1000 code, it says more drive time required... does anyone know how much driveing time it will take to go away?
thanks |
no, i made sure i set it back to stock before i took my truck in. right not on performance it has quite a bit of power but almost no smoke, if i put it back to stock and drive it alot, then reprogram it, will it blow smoke again? any idea how much driving it will take to reset?
![]() ![]() ![]() any help is greatly appreciated |
Maybe a few hundred miles?
What did you take it in for?
it would start real rough no matter how hot or cold it was outside, when it would get real cold id go to start it in the morning and it wold idle so low you could almost count when each cylinder fired, i was told to get the latest reflash, so i did. now it starts fine, im just wondering how long till that code goes away...
![]() ive gone about 300 miles stock and i tried to put the program back in it... same rusults. its getting frustrating, how long does this code usually appear? |
Forget the code. Just get an SCT and then you'll be making smoke.
psd
just drive it to AZ and back and it should be no codes then.
