06 f350 won't turn over. - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 20 Old 03-04-2014, 08:59 PM Thread Starter
Stumppy's Avatar
My dad's 06 powerstroke today wouldn't turn over when he tried to leave from work. He tried pulling codes and there were none. Everything lights up except the truck won't crank. Any info on where to start?
2004 CC SB 6.0
4 Inch Turbo back Exhaust
S&B Intake
Sct with Vivians looney wild tune.
Egr Delete
Arp Head studs and oem gaskets.
Stumppy is offline
post #2 of 20 Old 03-04-2014, 09:02 PM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Hydrolocked...?
What happened leading up to the no crank?
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #3 of 20 Old 03-04-2014, 09:04 PM Thread Starter
Stumppy's Avatar
Nothing he said it started right up this morning and he drove to work parked it and went out after work and it wouldn't crank. It has egr delete and external oil cooler. Tuned by Vivian.
2004 CC SB 6.0
S&B Intake
Egr Delete
Stumppy is offline
post #4 of 20 Old 03-04-2014, 09:05 PM
dfuzz78's Avatar
Any puking or anything?
Does he pop the hood at all?
Denis "Lt. Sled"
dfuzz78 is offline
post #5 of 20 Old 03-04-2014, 09:07 PM Thread Starter
Stumppy's Avatar
I do all his maintenance on it. No puking at all. Degas level is right at the min line.
2004 CC SB 6.0
S&B Intake
Egr Delete
Stumppy is offline
post #6 of 20 Old 03-04-2014, 09:25 PM
jmeaby's Avatar
Quoted: 16 Post(s)
does he have a monitor on? could be a ton of things need more info here. whats his battery voltage? icp? hpop? is the truck trying to do anything is it making any kind of noise? could also be a starter.
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #7 of 20 Old 03-04-2014, 09:35 PM
dfuzz78's Avatar
Not really "a ton" of things...
Maybe a couple of things, but like you said, what's the monitor say?
That could help us pinpoint it better.
Denis "Lt. Sled"
dfuzz78 is offline
post #8 of 20 Old 03-04-2014, 09:37 PM Thread Starter
Stumppy's Avatar
He doesn't have a monitor yet. I'm going over in the morning to throw my CTS on it and see what's going on and I will report back. He says it wouldn't click or make any noise other than the glow plugs cycling on and off.
2004 CC SB 6.0
S&B Intake
Egr Delete
Stumppy is offline
post #9 of 20 Old 03-04-2014, 09:41 PM
dfuzz78's Avatar
Can't really hear the glow plugs cycling, he's probably thinking of the vacuum pump.
Denis "Lt. Sled"
dfuzz78 is offline
post #10 of 20 Old 03-05-2014, 07:39 AM Thread Starter
Stumppy's Avatar
So I put my monitor on and it read 48 v ficm 11.6 v on the battery and I couldnt get a hopop reading because it wouldn't crank at all. I checked the fuses and they are all good. I'm not sure where to go from here.
2004 CC SB 6.0
S&B Intake
Egr Delete
Stumppy is offline
