Sct tuner 3015 help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-04-2014, 07:19 PM Thread Starter
Sct tuner 3015 help
Just got an sct tuner 3015 and went to load the pre loaded tunes to try out but it keeps failing. I tried a couple time but keeps failing. Even killed my batteries. am I missing a step?
AFE Stage 2 Intake
Arp Studs
Sinister Coolant Filteration Kit
IPR Gen 2 Egr Delete
MBRP 4 " Turbo - Back Exhaust
SCT Tuner with Edge Juice as monitor
Hercules FICM Tune
Bushwacker Fender Flares
20" BMF Rims
3712.5 Nitto Dune Grappler
:icon_ford
still-strokin is offline
post #2 of 8 Old 03-04-2014, 08:07 PM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
probably needs to be updated.
Connect it to your computer and go to the SCT website and update it to the current version.
Then try it again.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #3 of 8 Old 03-04-2014, 10:12 PM Thread Starter
Ok. Will do.
AFE Stage 2 Intake
Arp Studs
Hercules FICM Tune
20" BMF Rims
:icon_ford
post #4 of 8 Old 03-05-2014, 04:41 AM
Franchi's Avatar
Feedback Score: 22 reviews
How is it failing? Giving an error? Do update it as dfuzz said as that's always a good idea to have it up to latest firmware.
And make sure you are doing program vehicle, strategy tune, and following the on screen steps from there like turn key on, turn key off, ect ect
Franchi is offline
post #5 of 8 Old 03-06-2014, 03:00 PM Thread Starter
Talk to sct tech today. Went through couple things and nothing. I told him truck has a edge juice that I use just for monitoring. Said to disconnect the edge and see what happens.
AFE Stage 2 Intake
Arp Studs
Hercules FICM Tune
20" BMF Rims
:icon_ford
post #6 of 8 Old 03-06-2014, 03:17 PM
drivininidaho's Avatar
Quoted: 87 Post(s)
Is the truck "stock" or has it ever had a tune?
Lyndel
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
'04 F25 SD CCSB
studded, and having some issues.....
drivininidaho is offline
post #7 of 8 Old 03-06-2014, 03:48 PM Thread Starter
I just had a egr delete, coolant filter, new ficm php Hercules tune, heads gaskets again. Reused arp studs. So as far as I know just the edge juice. Not sure if tuned before. How can I find out
AFE Stage 2 Intake
Arp Studs
Hercules FICM Tune
20" BMF Rims
:icon_ford
post #8 of 8 Old 03-06-2014, 06:44 PM Thread Starter
Got it figured out. Disconnected the edge juice and the sct tuner loaded. Now need a powermax and a custom tune n truck will be in good shape
AFE Stage 2 Intake
Arp Studs
Hercules FICM Tune
20" BMF Rims
:icon_ford
