Climate control / tow haul wont work - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-02-2014, 04:54 AM Thread Starter
Friends,
I have a 2006 F 250 6.0 and my climate controls go on and off. The weird thing is that when the climate control goes out the tow/ haul will not work either. I have searched the web for answers but have found none. Any Suggestions? All of a sudden it will come back on. I am baffled.
Thanks,
FXWG
FXWG is offline
post #2 of 9 Old 03-02-2014, 09:16 AM
Originally Posted by FXWG View Post
Friends,
Thanks,
FXWG
Have you tried checking the fuse?
2004 F-250. 8" Pro Comp lift. 38" Toyo MTs. EGR delete. 4" MBRP straight pipe. Air Raid intake. SCT tuner. Edge Insight CTS.
Tx2va07 is offline
post #3 of 9 Old 03-03-2014, 03:39 AM Thread Starter
I have not checked the fuse because it is an on and off type of problem. I would think if it was a fuse it would not come back on once it goes off.
FXWG is offline
post #4 of 9 Old 03-03-2014, 07:00 AM
aka MacGyver
rick1067's Avatar
What type of HVAC control panel do you have?
rick1067 is offline
post #5 of 9 Old 03-03-2014, 07:07 AM
aka MacGyver
rick1067's Avatar
Looking at the wiring schematics, it is showing that Fuse 2.24 (15A) Provides power to both of those. I am not saying the fuse is blown but i woold make sure it is fully seated. I would also make sure (if you are not the original owner) that no one has pluged a wire into that slot to provide power somewhere else. I had this issue on my old truck and it had spread the connectors to the fuse wider than needed. That made the fuse not sit tightly into the slot.
rick1067 is offline
post #6 of 9 Old 03-03-2014, 08:57 AM Thread Starter
Thanks Rick, I will check all of that
FXWG is offline
post #7 of 9 Old 03-10-2016, 09:52 AM
Any luck on fixing this issue. Having the exact same problem.
05 SD 4x4 Crew Cab 6.0 EGR delete, coolant filter added, Stock
justintime_3 is offline
post #8 of 9 Old 03-10-2016, 09:58 AM
Anti-Hashtag Member
starcommtrey1's Avatar
Quoted: 496 Post(s)
Turn lights on and off.....saw this in a thread somewhere
Only two defining forces have ever died for you, one died for your soul, and the other died for your freedom. They are Jesus Christ and the American Military Service member. So, pray to God for your soul, and Thank a Veteran for the right to do so.
2007 King Ranch CC F-350 SRW
Performance Machines EGR Delete
Performance Machines Coolant Filter
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
starcommtrey1 is offline
post #9 of 9 Old 03-10-2016, 01:17 PM Thread Starter
Yes but I got lucky. The fuse itself was only connecting on one prong so when I hit a bump it would lose connection. I got the fuse in correctly and no more problems. Good Luck
FXWG is offline
