Weird fan engine fan action - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-01-2014, 06:24 AM Thread Starter
Ok so sometime when im driving down the road and i turn my heat on...the big engine fan cuts on within a couple seconds. I go to turn the heat off the big fan goes off. What does this mean?
Well the truck is sitting warming up i have the heat on so it will be warm in the truck when i get ready to drive. While driving the big fan wont come on and everything seems fine.
Just wonder if thats a promblem? Its not summer yet so i dont know if it will do it with the a/c on.
junior3 is offline
post #2 of 4 Old 03-01-2014, 06:44 AM
Term3's Avatar
That's odd. Where is your heat selected to go? If it is defrost the A/C will kick in every few seconds to dehumidify the cold air being brought into the heater to help prevent fogging on the inside surface of the windshield. So perhaps its a A/C relay issue commanding the rad fan to engage??? See if it does the same thing when you direct the heat to the floor.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 4 Old 03-01-2014, 06:55 AM Thread Starter
So far i just use heat for defrost and the heat setting for blowing towards me and the floor.
junior3 is offline
post #4 of 4 Old 03-01-2014, 07:02 AM
Term3's Avatar
Only thing I can think of is to check the condition of the wiring coming from the center of the fan clutch. Maybe the wiring got nicked by the fan blades. Maybe someone else can chime in on this problem.
Term3 is offline
