P0263, u1900 no start help. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-27-2014, 06:52 PM Thread Starter
I replaced the #1 injector for the 0263 code. Fired up after after 6 tries and idled fine. So I jumped in and took it for a spin. Got down the road and lost power again. Finally it stalled and would not start again. This is what happened before I replaced the injector. The u1900 code did not show up until I tried to start it numerous of times. I am lost, FICM?
Tpea1979 is offline
post #2 of 4 Old 02-28-2014, 08:36 AM
aka MacGyver
rick1067's Avatar
You can check the FICM. To test see the video.
Although you are not getting a code for chaffing, I would also check for resistance in the wires from the FICM A plug to your #1 Injector with a multimeter. The resistance should be less than 5 Ohms.
Under the FICM, the plug closest to the firewall is plug A. It contains all of the wires goint to the #1 Injector.
At you top of the head, on the #1 injector, this is the wiring for that plug.
rick1067 is offline
post #3 of 4 Old 02-28-2014, 12:39 PM Thread Starter
Checked the FICM and have 48 volts. I have only a U1900 code now and that is not going to not let it start. This is such a headache. Especially when this is the first problem since i first bought the truck. I have heard that the fuel pump will run on 0 pressure (from a guy at a well known diesel shop) I hear it whining and pumping fuel. I pulled off the fuel filter on top of the motor and turn it over and it is bubbling. I have read about something on/in fuel pump but have no idea what and where it is. I really dont want to drop 1k's on this thing. I am getting to the point of making it run and getting a new one. But I dont want a truck payment especially when i only have 122,000 on this thing. HELP...
Tpea1979 is offline
post #4 of 4 Old 03-03-2014, 08:21 AM Thread Starter
Well got the truck running and it has ran dine for 2 days. I think the fuel pump lost prime. Got the truck running and it was running great until today. Never died but felt like it was missing. Got the code 0263 again. Turned off truck and it idled fine. I don't have a clue what this could be. HELP
Tpea1979 is offline
