03 6.0 crank no start..sits for days then starts but dies - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-27-2014, 03:34 PM Thread Starter
Gman239's Avatar
Quoted: 106 Post(s)
2003 6.0 cranked with no start. Replaced FICM, didn't solve the problem. Had it towed to the shop. No codes showing up on edge cts. Shop says truck starts fine. So pick the truck up drives fine 3 miles down the road. Park the truck and while it's at idle it dies and just cranks but will not restart.
Shop says no codes are found and the FICM was replaced. Only mods are egr delete and edge cts. Oil level is good and truck was running fine with no issues before this.
What should I be looking into for possibilities?
Gman239 is offline
post #2 of 8 Old 02-27-2014, 05:58 PM
midnite rider's Avatar
Quoted: 285 Post(s)
What fuel pressure are u running. Pump could failing.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #3 of 8 Old 02-27-2014, 07:11 PM Thread Starter
Gman239's Avatar
Quoted: 106 Post(s)
Midnite rider sorry for the stupid question but how would I check that exactly?
Gman239 is offline
post #4 of 8 Old 02-28-2014, 11:52 AM
mrenn's Avatar
Quoted: 3 Post(s)
What is your ICP and IPR at during the crank cycle?
ARP,EGR Delete,SCT,4.56 gears,powermax,Banks Techni-cooler,Adrenalin HPOP,Donohoe springs,fox shocks,airbags,blue spring,38x15.5 M. Thompson's,4 10's,2 tv's,playstation,amp-steps,2013 tailgate,edge cts
2016 Lariat 6.7.
mrenn is offline
post #5 of 8 Old 02-28-2014, 04:22 PM
Quoted: 285 Post(s)
There is a plug on upper fuel bowl on drivers side towards the bottom. Not sure what size allen it takes. Remove the plug and use a fuel pressure test gauge.turn key on and see what the pump will deliver, might have to cycle the pump 2 or 3 times.
-Tom
post #6 of 8 Old 03-12-2014, 07:29 PM Thread Starter
Gman239's Avatar
Quoted: 106 Post(s)
Just somewhat of an update, after 2 weeks at the shop it's still throwing a code for the FICM. Why is this if the FICM was just replaced? Is there some wiring to/from it that is causing a short or something? We can't really check anything as it's still sitting at the shop.
Gman239 is offline
post #7 of 8 Old 03-15-2014, 11:12 AM Thread Starter
Gman239's Avatar
Quoted: 106 Post(s)
Update got it back from the shop, evidently the edge was interfering with the FICM somehow. The mechanic said he had seen this before and didn't recommend the edge cts on the 6.0. First time I heard of that. Anyway unhooked the edge and reset the codes and now the truck starts every time and runs fine.
So wasted 450$ for a new FICM when it was the edge in the first place? Lesson learned I guess. Now if I could only find out what's wrong with my 7.3.
Gman239 is offline
post #8 of 8 Old 03-15-2014, 04:23 PM
Quoted: 285 Post(s)
Can`t believe that a monitor would affect the ficm, but stranger things happen.
-Tom
