leaking coolant/ lack of heat/ low temps - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-27-2014, 07:21 AM Thread Starter
dirtydieselsixohh's Avatar
hey guy i was wondering if you can help me out. i have noticed im loosing coolant from the degas cap (updated cap) i have heat that comes and goes. and exhaust or maybe coolant smell in the cab on start up and i was lucky enough to borrow my brothers Dash Daq monitoring system for a few days and my EOT agv around 182 city driving and ECT range from 170-178 delta avg 6-7 degrees but ive seen as higher at WOT. im EGR deleted with an updated oil cooler i did over the summer i just changed my oil and added rev x this time
im praying its not a head gasket issue, i would like to think the thermostat has something to do with it and maybe a heater core issue as well or air in the system
also what are some other thing to monitor and what should the temp/psi/voltage be
i just put 3,000 into a lift and tires i might cry if i have to dish out another 3,000 for studs and hg repair, tuner, oil cooler, coolant, coolant filter
dirtydieselsixohh is offline
The Following User Says Thank You to dirtydieselsixohh For This Useful Post:
dannyreed (03-03-2014)
post #2 of 4 Old 02-27-2014, 08:41 PM
andyjman's Avatar
Quoted: 2 Post(s)
There's 3 things that will cause coolant to puke from the bottle.
1. Blown head gaskets or cracked head
2. Bad egr cooler
3. Serious over heating.
You need to run a coolant pressure test, there's multiple threads posted recently in this section describing how to do the test, what symptoms to look for, and what possible solutions exist.
05 F350 CC LB FX4 Lariat, ARP studs, Barder 2.5 turbo,warren 175/30 injectors, Odawg ported manifold, S&B cold air, sinister coolant filter, Twisted Stage III Trans, DPC Conv, Mishi Rad BPD water pump, EGR delete, MBRP turbo back exhaust no muffler or kitty, edge insight monitor, tunes from Matt @ geadheads, rancho rs9000xl adjustable shocks .
My House Has A Ford Problem!!!! lol
andyjman is offline
post #3 of 4 Old 02-27-2014, 09:29 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
What are ambient temps where you are at? How long are you driving it?
Sent from AutoGuide.com App
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #4 of 4 Old 03-03-2014, 09:16 AM Thread Starter
temps are 10-30F degrees outside and when i was recording the ect and eot i was driving for about 45min. i just ordered a thermostat last night ill see how things go from there
2006 f350 cclb 35x18 nitto trailgrapplers 4.5 inch icon lift egr delete oil cooler upgrade 2013 tailgate 185kmiles and going
