Front End Clunk - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-27-2014, 04:15 AM Thread Starter
Front End Clunk
2003 F250 4X4. Loud clunking noise from what appears to be passenger side front. Currently 142K on truck. Original Ford ball joints replaced with Moog's at 65K. New sway bar links, sway bar bushings and front shocks. When I raise the front end and shake the wheel at 12 and 6 I have no play. At 3 and 9 I have considerable side to side movement. No vibration in the wheel, no pulling, no grinding noise. Just loud clunking over bumpy roads.
Assuming from the side to side play its a wheel bearing/hub going bad??
Bubbalarge
Bubbalarge is offline
post #2 of 3 Old 02-27-2014, 10:06 AM
duck fan's Avatar
Check the bushings in the swaybar endlinks. They don't typically last very long and when they go bad, it sounds like someone is hitting the floorboard with a rubber mallet.
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #3 of 3 Old 02-27-2014, 03:27 PM
midnite rider's Avatar
Quoted: 285 Post(s)
Could be a loose shock, bad swaybar bushing, or the exhaust hitting the underside somewhere. noises drive me crazy.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
