urgent need opinions - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-26-2014, 08:31 PM Thread Starter
agonzo90's Avatar
Exclamation urgent need opinions
So on a test drive after new injectors cold air intake and 58v ficm oil started leaking from the front bottom of the motor and now won't start is it just the lpop or could it just be the seal kinda freakin out me and this truck have been on a very very ruff road
agonzo90 is offline
post #2 of 9 Old 02-27-2014, 02:22 AM
Did you check the crank shaft for a wear sleve and replace it?
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 9 Old 02-27-2014, 04:03 AM Thread Starter
agonzo90's Avatar
No never heard of that being an issue
agonzo90 is offline
post #4 of 9 Old 02-27-2014, 11:45 AM
aka MacGyver
rick1067's Avatar
First thing I would do is check the oil level. If you are leaking oil and the level is to low, the motor will not crank.
rick1067 is offline
post #5 of 9 Old 02-27-2014, 11:58 AM Thread Starter
agonzo90's Avatar
Figured it out lpop went out with a bang
agonzo90 is offline
post #6 of 9 Old 02-27-2014, 12:29 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
That would have been my guess based on the location of the leak.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #7 of 9 Old 02-27-2014, 12:52 PM Thread Starter
agonzo90's Avatar
Yea so new lpop and timing cover
agonzo90 is offline
post #8 of 9 Old 02-27-2014, 02:07 PM
COONASS
WHAT HAPPENED's Avatar
let us know how it works out
2005 CCLB FX4
ARP, EGR Delete, 5 inch TB, SCT Livewire, Sinister Coolant filtration, ECL-1, PHP TUNES
Federal Ownership Respectfully Declined
WHAT HAPPENED is offline
post #9 of 9 Old 02-27-2014, 02:11 PM Thread Starter
agonzo90's Avatar
Should know here in the next couple hours I'll be sure to post the results
agonzo90 is offline
