Heating and cab smell - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 27 Old 02-25-2014, 08:53 PM Thread Starter
mustangcobrajc's Avatar
Question Heating and cab smell
Ok i replaced my turbo and just did a full flush with restore and vc-9 and now have ECL 1 coolant and new thermostat. Also just installed sinister coolant filter before doing flush and then changed filter after all flushes. Now i will get no heat at all until the thermostat opens but then no heat once it will close. I notice that i will get to about 212* before it even opens but I've seen it range from 170-216* so maybe need a different thermostat instead(will get a new OEM) but after doing the flush i did notice my EOT is no where near as high or as far off of ECT as it use to be so that is a good sign for my oil cooler for now. Also once i start getting a little bit of heat it also comes with horrible engine exhaust smell in the cab, enough to make you almost gag and if it idles long enough when you open the door it is a little hazy inside the Cab but will be blowing more hot air. Any ideas on why im not getting any heat until my thermostat opens and ECT drop back down and also why im getting horrible exhaust smell when i do start to get hot air.
05 F350 Harley CCLB 6.0L
SOLD!!!
General Grabber AT2 315/75-16 w/Newton 2.5" Level
5" Diamond Eye Turbo-back Straight pipe
Garret Stage 1 Turbo, ARP head studs
Sinister EGR delete, Sinister Coolant Filter
High Idle, CCV MOD to atmosphere
Blue Spring
Mag-Hytec trans pan and Diff cover
SCT Livewire 5015 custom tuned by Quicktricks
mustangcobrajc is offline
post #2 of 27 Old 02-25-2014, 11:09 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Pressure test your cooling system. Sounds like blown head gaskets
Sent from AutoGuide.com App
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 27 Old 02-26-2014, 06:58 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
The wildly varying temps are either from lots of air in the coolant system or from a HG issue.
The smell in the cab may be exhaust from your turbo reinstallation not having the up-pipes or down-pipe mated correctly. Why it happens when you get heat is a separate issue, unless you have a leak in your heater core and exhaust gas is coming through your coolant system.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 27 Old 02-26-2014, 04:58 PM Thread Starter
Well I will have to pressure test it when I get a tester. Now today driving to work back and fourth about top 45mph. Was getting heat and temp only between 186-196. Went to drive down highway to go out with wife and it over heated...230-240* and also I get a whining noise while driving. Soo possible crap thermostat, water pump, cracked/leaking heads is my guess.
SOLD!!!
Blue Spring
post #5 of 27 Old 02-27-2014, 08:11 PM Thread Starter
Well this is what i found so far. Driving around the local area it gets to about 206 even with now thermostat but goes back down. If i drive on the highway for about 5min+ it will start over heat and get up into the 236-240*range. The whining noise only happens or is noticeable when it gets to about 218*+. Once it gets in the overheat range, and i drive slowly around local area it still wont drop under 234-236 unless i turn it off and let it sit for a few min. I am starting to think more of a water pump going bad or possibly did not mix the coolant/water good enough and cant dissipate the heat good enough when under heavier loads...If worse it has to be the head gaskets. This post seems to be the same exact problem that i am having, http://www.thedieselstop.com/forums/...77/index2.html also does anyone have any how to for replacing the 6.0 water pump. Never really done one myself and hope its not too difficult of a job.
SOLD!!!
Blue Spring
post #6 of 27 Old 02-27-2014, 10:50 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Water pump is shot. Pressure test the system as well
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #7 of 27 Old 02-27-2014, 10:51 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Because the bad pump doesn't explain the smell. How do your up pipes look
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #8 of 27 Old 02-28-2014, 05:34 AM Thread Starter
up pipes looked pretty good while i had to turbo off, did not see really any black on the pipe or firewall from a leak. I know the Down pipe might be part of the problem because when i tried to line it back up with the turbo it was giving me a fit and kept wanting to pull apart. My new 5" exhaust should be here by early next week so ill see if that takes care of it. For the water pump, would a Napa one be ok, i read theres are made out of steel now and not plastic like the OEM as long as my water pump housing is fine. Not quite sure what the difference is http://www.napaonline.com/Catalog/Ca...079_0258154772 vs http://www.napaonline.com/Catalog/Ca...504_0258176495
SOLD!!!
Blue Spring
post #9 of 27 Old 02-28-2014, 07:27 AM
Quoted: 46 Post(s)
Not quite sure what the difference is NAPA AUTO PARTS - Home vs NAPA AUTO PARTS - Home
Cast iron vs aluminum casing.
Frank
Working for Toys
post #10 of 27 Old 03-01-2014, 09:52 AM Thread Starter
Well neither of those pumps were for a 6.0 once i looked for them.. LOL i ended up getting this one tho NAPA AUTO PARTS now i just have to take it some where i guess since i cant get my hands on a fan clutch tool since local auto zone does not have one. Hopefully wont break the bank
SOLD!!!
Blue Spring
