NEW OWNER! HELP - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-23-2014, 05:40 PM Thread Starter
Exclamation NEW OWNER! HELP
I bought a 2006 6.0 when I bought the truck I noticed the lights surged a little bit at idle and while driving. Well now its worse. The other problem I have is when the truck is cold the motor cuts in and out you can hear it in the exhaust, soon as I hit operating temp it goes away but when I get on the pedal it will cut in and out like its not getting something correctly. At a light whether cold or warm the idle moves a tiny bit up and down. I changed oil, oil filter and fuel filters about 3K ago. It has no problem starting warm or cold. If you don't get on the gas hard you wouldn't know it had a problem other than the idle, under normal driving condition it goes threw gears fine no problems. I also cleaned the egr, the vgt and replaced a boost line that has a little crack in it. Any help would be awesome thank you.
06PowerStroker6.0 is offline
post #2 of 8 Old 02-23-2014, 05:45 PM Thread Starter
also the truck has 354,000
post #3 of 8 Old 02-23-2014, 09:09 PM
andyjman's Avatar
Quoted: 2 Post(s)
Sounds like u might have injector stiction. As far as ur electrical issue, what do u mean the lights surge? Do they get bright and dim as u drive? Or what's goin on? Sounds like ur alternator could be goin out.
05 F350 CC LB FX4 Lariat, ARP studs, Barder 2.5 turbo,warren 175/30 injectors, Odawg ported manifold, S&B cold air, sinister coolant filter, Twisted Stage III Trans, DPC Conv, Mishi Rad BPD water pump, EGR delete, MBRP turbo back exhaust no muffler or kitty, edge insight monitor, tunes from Matt @ geadheads, rancho rs9000xl adjustable shocks .
My House Has A Ford Problem!!!! lol
andyjman is offline
post #4 of 8 Old 02-24-2014, 12:15 PM Thread Starter
ok sorry I didn't want to respond until I grabbed the edge insight... as far as the dimmin of lights the exterior and interior lights and cluster dim with the idle. battery level is at 14.2 ko/engine off ficm is 49 ko/enging off icp is 629 ko/engine on. When truck is running battery level goes to about 13.8-13.5 the ficm goes between 48.5-49.5 while running. After the truck is warm it will run fine unless I step on then it feels like the power stops and goes really fast like a noticeable popping in the exhaust.
post #5 of 8 Old 02-24-2014, 04:22 PM
midnite rider's Avatar
Quoted: 285 Post(s)
DO you have anything leaking on your pulleys, sounds like the belt might be slipping. try spraying some cleaner on the belt.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #6 of 8 Old 02-24-2014, 08:09 PM Thread Starter
I will check but I doubt a slipping pulley will make the truck feel like a miss fire.....I could be wrong
post #7 of 8 Old 02-24-2014, 08:23 PM
john galt's Avatar
Quoted: 1094 Post(s)
I was thinking you should try to check out your alt voltages. Sounds like maybe the voltage regulator is not staying steady causing surges? or a wire is lose or corroded and not keeping a constant voltage? just guessing here but,
as for power surge in the engine? maybe the ficm is acting weird due to voltage variation? sounds to me like it should all be related but i am not certain how
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, sinister coolant filter(this is the ONLY pos sinister product that will ever be on my truck), riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #8 of 8 Old 02-24-2014, 09:22 PM
Rocweiller's Avatar
Quoted: 2 Post(s)
Try some rev x for the oil stiction.
2008 F250 XLT SBCC grey flake, 33x12.50 Toyo m/t's on 18 inch mammoth wheels. Rhino lined go rhino nerf bars. S&B cai,Spartan tuned and straight piped. Fake *** chrome grille removed and a matching colored grille put in place.
Rocweiller is offline
