scanguage 2 - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-22-2014, 08:15 PM Thread Starter
scanguage 2
Wifes truck died the other day while she was driving like someone turned the key off. No warning and no symptoms, so will the scan gauge 2 help me diagnose? Can it measure parameters for the IPR and ICP? I would like to get it running soon and I suppose while im in there ill delete the egr and rebuild oil cooler, replace dummy plugs and standpipes and the stc. Probably will go with new ipr and icp since I cant figure out wth is wrong.
lifted dually is offline
post #2 of 3 Old 02-22-2014, 08:18 PM Thread Starter
Forgot to mention its an 07 with a 84k. And if anyone has any suggestions im all about it. Gonna tear into it in the morning and see what I can find
post #3 of 3 Old 02-23-2014, 01:04 AM
The SGII is a good monitor system if set up properly but is by no means a full scan tool, it can not run any of the specialty tests that may be needed to find your issue.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
