Need to know my problem! - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-21-2014, 08:28 PM Thread Starter
Quoted: 3 Post(s)
I have had injector missing for a little while now, only when it runs a little cold, when it gets warn to 190 eot it runs fine, but anything before 190 it misses and even one time cut off on me, i feel like I've lost power, and i need to know if i have a high pressure oil problem or a bad injector? My icp and ipr readings seem normal, they haven't changed, i know you can buzz test for ba injectors, but i want to know what my problem is without blowing money. Feel free to help and ask me plenty of questions so we can get to the bottom of it, thanks
[color=gray]Sent from AutoGuide.com Free App[
mySIXOisSick is offline
post #2 of 9 Old 02-21-2014, 09:19 PM
andyjman's Avatar
Quoted: 2 Post(s)
Is your check engine light on? If so try pulling the codes and see if you get a cylinder contribution code. When was the last time u changed ur oil, fuel filters, etc
05 F350 CC LB FX4 Lariat, ARP studs, Barder 2.5 turbo,warren 175/30 injectors, Odawg ported manifold, S&B cold air, sinister coolant filter, Twisted Stage III Trans, DPC Conv, Mishi Rad BPD water pump, EGR delete, MBRP turbo back exhaust no muffler or kitty, edge insight monitor, tunes from Matt @ geadheads, rancho rs9000xl adjustable shocks .
My House Has A Ford Problem!!!! lol
andyjman is offline
post #3 of 9 Old 02-22-2014, 04:36 AM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
Perfect description of Injector Stiction
Please
You could save the life of a sick child
NYC F-350 is offline
post #4 of 9 Old 02-22-2014, 05:55 AM Thread Starter
Quoted: 3 Post(s)
Im actually do for an oil and fuel filter change this week, no check engine lights, i pulled a cylinder 5 and 8 contribution code when i last checked i believe
post #5 of 9 Old 02-22-2014, 05:56 AM Thread Starter
Quoted: 3 Post(s)
I know thats cause by the oil side of the injector, so would that be caused by a high pressure oil problem or a bad injector problem?
post #6 of 9 Old 02-22-2014, 07:07 AM
NYC F-350's Avatar
Quoted: 51 Post(s)
Check out the thread: Fixing stiction
Please
post #7 of 9 Old 02-22-2014, 07:25 AM Thread Starter
Quoted: 3 Post(s)
Thanks for the great link, i might try that, but im betting that pulling all the injectors is a pain
post #8 of 9 Old 02-22-2014, 01:42 PM
midnite rider's Avatar
Quoted: 285 Post(s)
5w40 with some rev x or archoil, then take it out and run the sh-t out of it. If it is stiction good chance it will clear up.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
The Following User Says Thank You to midnite rider For This Useful Post:
Corey@CNCFAB (02-23-2014)
post #9 of 9 Old 02-23-2014, 01:12 AM
You may want to do a little testing before you throw money at it but it is your money so watse it if you want to.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
