03 no start - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-21-2014, 03:12 AM Thread Starter
03 no start
I have a 03 f350 it was running than it died took it to my shop got it running but there was no power so I got into it and found on the ipr wires the two that run into the ipr were bare and touching each other fixed it and still no start the icp pressure was at 550 before all this and still never stared so went after the ipr the screen was in good shape just the wires were bare and touching each other.. thing that throws me off is the ipr% is at 15 key on engien off and cranking jumps 85.. I know its not supposed to be that im just lost I unplugged icp and still no start help
Fountainkid101 is offline
post #2 of 11 Old 02-21-2014, 05:21 AM
ps_lane01's Avatar
Quoted: 10 Post(s)
So the numbers you are seeing is what the pcm is telling the ipr. So 15% koeo is correct 85% is the ipr fully closed to build starting icp. My guess is your ipr needs to be replaced, unplugging the icp tells the engine that their is 550 psi of pressure and the engine will start... HOWEVER, if the ipr is staying 15% open because it is broken then the engine will not ACTUALLY build 550 or equivelant icp pressure. Make sense? What is icp koeo and icp at starting while plugged in? Icp should not stay directly at 550 icp, it should fluctuate and show movement in pressure.
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #3 of 11 Old 02-21-2014, 06:06 AM Thread Starter
It started out at 550 and now its only like 35 psi when I found those wires on the ipr was bare and touching I thought that would be my problem but its still showing 15% key on amd jumps to 85% in a couple cranks so could those bare wires fry the ipr vavle and the psi is still 35
post #4 of 11 Old 02-21-2014, 06:18 AM
ps_lane01's Avatar
Quoted: 10 Post(s)
Cool! Alright either the ipr is still messed up or u have a hpo leak, in which case you would need to perform a "hpo shop air leak test" - do a search here you will find procedures and results. As long as your icp and ipr are in working condition, it sounds like the main seal blew out in the hpop.
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #5 of 11 Old 02-21-2014, 06:30 AM Thread Starter
Ok will do thanks for the info... when u do the shop air test I have to have the key on. But u think those wires fried the ipr the screen was clean and not broke
post #6 of 11 Old 02-21-2014, 06:38 AM
ps_lane01's Avatar
Quoted: 10 Post(s)
Only if you command ipr closed with a software. Otherwise, you want the car off and your going to pressurize the system with air through the icp and apply 12 volts directly to the ipr to close the loop so the hpop system is sealed and pressurized then follow the gurgling or air sound.
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #7 of 11 Old 02-21-2014, 06:50 AM Thread Starter
OK thanks for all the information..
post #8 of 11 Old 02-21-2014, 07:32 AM
mrenn's Avatar
Quoted: 3 Post(s)
If you are already digging deep on an 03 to pull the IPR and ICP you might as well pull the pump.There is a bearing on the side that is proned to coming out and causing the IPR to reach 85 % and cause a no start situation.Doesnt hurt since you are already in there.If you do find the bearing gone,dont worry you do not need to spend 500+$ on a new pump.Mine came out and I threaded the hole and put a 1/4" fitting in there and tack welded it to the pump so I never have this issue again.The pump itself almost never goes bad,its always that stupid bearing they put in there.Food for thought.
ARP,EGR Delete,SCT,4.56 gears,powermax,Banks Techni-cooler,Adrenalin HPOP,Donohoe springs,fox shocks,airbags,blue spring,38x15.5 M. Thompson's,4 10's,2 tv's,playstation,amp-steps,2013 tailgate,edge cts
2016 Lariat 6.7.
mrenn is offline
post #9 of 11 Old 02-22-2014, 05:42 AM Thread Starter
i did the air test and didnt hear nothing have the passenger vavle cover off and still didnt hear anything... originally u could hear air but it sounded like in the oil pan then it seemed like the ipr vavle closed with key off and no air anywere dead quit.. and it didnt matter if the key was on or off still nothing im stuck they say put 12v to the ipr but with the key on i put a meter on the plug and there was 12v but u couldnt hear no air.. and im getting 0 psi on icp with scanner or mechanical guage on it nothing.
post #10 of 11 Old 03-05-2014, 07:08 AM
ps_lane01's Avatar
Quoted: 10 Post(s)
Where did you put the compressed air into the system? At the icp? 12 volts need to be applied directly to the ipr and should only be applied 30 seconds at a time or you risk damaging the valve. When the oil is cleared from the system the ipr valve should make a slight click when 12v is applied. The engine should be off for all of this. When the ipr is not charged you will hear air and gurgling. When the ipr is charged you SHOULD hear nothing at all (if the system is sealed), if there is a leak u will hear gurgling but may take a few times to clear the oil out before really hearing the air.
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
