"Trailer Fault - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-20-2014, 04:46 PM Thread Starter
"Trailer Fault
Sorry I have not been able to find exactly what I was looking for but here is my problem. The truck I drive for work is an 06 F550 with a flatbed on it. Recently it has been giving the Trailer Fault warning, but I have no trailer hooked up. It has a 6 pole round connector and a 7 pin wire connector. I have blown both out and checked connections. It also only does it when you press the brakes and when the left turn signal is on, but not the right turn signal. This makes me think it is something in either the wire or the fuse for the left turn signal and brake light. Does anyone else have an idea, its pretty annoying to drive through town.
Thanks
FORDDIESEL276 is offline
post #2 of 8 Old 02-20-2014, 09:31 PM
andyjman's Avatar
Quoted: 2 Post(s)
Try spraying the trailer connector out with some brake cleaner n it'll chase any moisture out, and wipe out any old electrical grease with a q tip. Mine was doing the same thing. Itdd say "tbc" fault when I applied the brakes. Doing this fixed it.
05 F350 CC LB FX4 Lariat, ARP studs, Barder 2.5 turbo,warren 175/30 injectors, Odawg ported manifold, S&B cold air, sinister coolant filter, Twisted Stage III Trans, DPC Conv, Mishi Rad BPD water pump, EGR delete, MBRP turbo back exhaust no muffler or kitty, edge insight monitor, tunes from Matt @ geadheads, rancho rs9000xl adjustable shocks .
My House Has A Ford Problem!!!! lol
andyjman is offline
post #3 of 8 Old 02-21-2014, 05:25 AM
ps_lane01's Avatar
Quoted: 10 Post(s)
Clean the square inboard connector real good too. Its about 2 feet of wires from the bumper connector.
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #4 of 8 Old 02-21-2014, 05:34 AM
That double plug harness is a short pig tail that connects to another plug in the main harness, you may want to clean it as well. Also look at the harness it self for chafe spots not just to ground but wire to wire as well.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #5 of 8 Old 02-21-2014, 05:57 AM
It could be you break sensor, it is located on your break pedal. I was getting the tbc fault until I changed the sensor, the beeping drove me nuts. I think the sensor is 27 bucks from ford.
pperchansky is offline
post #6 of 8 Old 02-21-2014, 06:14 AM
ZMANN's Avatar
Quoted: 1669 Post(s)
thats not factory unless you meant 5 pin flat and a round 7 pin blade
but agreed most issues are at the connections
We Miss you Ronnie
ZMANN is offline
post #7 of 8 Old 02-21-2014, 04:18 PM Thread Starter
Thanks for the help I will try the suggestions. The truck has a flatbed on it that a local company put on so the 6 pole round connector is not factory. Does anybody know of a fuse that would at least stop the beeping. We mainly use the truck to haul not tow, but the beeping will drive you crazy.
Thanks for the help
post #8 of 8 Old 02-21-2014, 07:53 PM
sabarnes's Avatar
Try pulling the trailer relays if they run on a secondary brake/ turn signal relay.
sabarnes is offline
