07 no start low icp diagnosed still nothing please help - Ford Powerstroke Diesel Forum
post #1 of 17 Old 02-19-2014, 06:22 AM Thread Starter
2007 ford f250 114,000 miles just recently had no start did dummy plugs and stand pipes ran fine for a day now a no start again bought a scan gauge and heres what i got
ficm 48v 44 to 48 while cranking
ficm syc 1 while cranking
ipr jumped from 14% to 84.7% while cranking
icp reaches 400psi
i took ipr out the screen wasnt torn and there was barley any build up on it i pushed valve in to make sure it seated back properly and cleaned it off and reinstalled put every back and still no start ive been researching for days and every post i see about low icp there showing 300psi or lower why is mine pumping so high like its almost there but not enough please help truck has been down for a while and its my dd i havent had time to perform a leak test i really cant afford the adapter or have time to wait for it to be shipped any help would be great
6ohlariat07 is offline
post #2 of 17 Old 02-19-2014, 06:28 AM
6.0 Killer
Have same problem let you know when I do mine today..
markdarr66 is offline
post #3 of 17 Old 02-19-2014, 06:53 AM Thread Starter
thanks it sucks i have to work on mine outside i dont have a shop anymore and the weather here in pa isnt the greatest hope it works out and you find the problem
post #4 of 17 Old 02-19-2014, 09:01 AM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
In what???
Please
You could save the life of a sick child
NYC F-350 is offline
post #5 of 17 Old 02-19-2014, 09:05 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
The adapter is not expensive - it is a lot cheaper than replacing a good part! If you are going to do the work, you need to know what is wrong with it. Don't forget that you need to close the IPR electrically after you apply air to find the leak.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #6 of 17 Old 02-19-2014, 09:12 AM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 370 Post(s)
One of your injector orings could be bad. Supply tube could be cracked. Oring off the back of the pump could be bad. The fact that it builds 400 psi tells me ipr is good. Unfortunately you're going to have to do a leak test sounds like to me. Best of Luck
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #7 of 17 Old 02-19-2014, 09:49 AM Thread Starter
the first day i tested it the icp went to 350 then today it went to 400 what gets me is that it ran fine after the new dummy plugs i only started it once and drove it for an hour and shut it off and wouldnt start back up could it possibly be the stc fitting and where can i buy the adapter im guessing i have to order it off line and wait for it and can i use a regular compressor to do the test i dont have a way to get it to a shop
post #8 of 17 Old 02-19-2014, 09:52 AM Thread Starter
Originally Posted by NYC F-350 View Post
In what???
what do you mean? i took the ipr out and the screen had alil bit of build up i took the screen off to clean it as best as i could and i looked down in the valve to see if anything was down there like any build up stopping it from seating and just to be safe i pushed the valve in and sprayed cleaner in the holes where the spring is but it looked like it seated fine once i let off the valve
post #9 of 17 Old 02-19-2014, 09:56 AM
NYC F-350's Avatar
Quoted: 49 Post(s)
I just had no idea what you meant. Thanks for clearing that up
Please
post #10 of 17 Old 02-19-2014, 09:58 AM Thread Starter
could the stc fitting be bad and still build 400psi i wanna do the air test but i really dont have time to wait for the adapter to be shipped
