ficm failure 6.0 50 amp fuse - Ford Powerstroke Diesel Forum
 7Likes
post #1 of 18 Old 02-18-2014, 11:09 AM Thread Starter
Paulliewog's Avatar
Anybody have some advice on figuring out ficm failure and 50 amp fuse blowing.
Have a BulletProof Diesel ficm supply set at 58V and keeps blowing the 50 Amp fuse. Eventually even toasted the BPD supply too!! Any help at all?? I called up BPD and they sent me a new piece and it got the engine to start again, but still have a long long crank and have to hold the starter engaged till it will stay running.
'05 F-350 King Ranch, lost the muffler.
can't find my cat???
SCT tuner, 58V Bulletproof Diesel 6 phase FICM upgrade
Paulliewog is offline
post #2 of 18 Old 02-18-2014, 11:12 AM Thread Starter
Paulliewog's Avatar
By the way!! The new ficm supply is set for stock 48V. and I only tried to start it once!! I don't wan't to blow another ficm to something I could be overlooking.
post #3 of 18 Old 02-18-2014, 02:28 PM
You need to find out if that is a shared circuit that powers more than one thing.
Something else may be blowing the fuse.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #4 of 18 Old 02-18-2014, 02:47 PM
ZMANN's Avatar
Quoted: 1357 Post(s)
interesting
the BPD has no related issues that I have ever read about who at BPD did you deal with ?
any input from them ? are they giving your old one a autopsy did they just send the power supply or did they send u a complete unit ?
any way to monitor some pids ? the SCT should work with a laptop ?
you only tried to start it once I would do it some more if it were mine and see if it clears up
We Miss you Ronnie
ZMANN is offline
post #5 of 18 Old 02-18-2014, 03:44 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
I doubt there is anything else on that circuit unless someone did something they shouldn't have.
Here is a quote from a thread from this morning that may explain all this..From one of the helpful folks over at BPD
If you bought it 15 months ago, it's an earlier revision power supply. When our vendor went to machine placing (vs. hand placing) the components on the boards, we had some quality control issues. This caused poor solder joints on a few of the smaller parts. This in turn would cause the power supply to fail.
We have since changed the layout, component placement and quality control. If it turns out that you have this issue, Andrew will expedite getting you a new one under warranty.
So, he may have been one of the unfortunate few that got one of those and that is what blew the fuse.
I wouldn't hesitate trying again if it was me. You only tried one turn of the key....
Paulliewog likes this.
Please
You could save the life of a sick child
NYC F-350 is offline
post #6 of 18 Old 02-18-2014, 11:37 PM Thread Starter
Paulliewog's Avatar
I am going to try again but I don't wan't to work on it during this -30 degree weather we are having. Plastic parts don't like to be touched when they are cold. Not only that I don't want to expose the electrical system to any possible snow or water that may drop onto opened connectors. Supposed to warm up to slightly above freezing, I just hope a day or two of sun to go along with that would be nice.
post #7 of 18 Old 02-18-2014, 11:44 PM Thread Starter
Paulliewog's Avatar
I spoke with Andrew Presley. He has been a great help so far. Just the fact that they warrantied the supply puts them up at the top far above anyone else.
I do not have a scan tool that will read all the PID'S that I need, nor any wiring diagrams.
I'm gonna try the truck again hopefully by this weekend to see how things go.
Sentinel@BPD likes this.
post #8 of 18 Old 02-19-2014, 11:11 AM
Slacker
Evil Eye's Avatar
Quoted: 193 Post(s)
Feedback Score: 4 reviews
BulletProof Diesel is the BEST when it comes to customer service and they continue to prove it. Glad that you were able to speak with Andrew. Best of luck and keep us posted.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #9 of 18 Old 02-19-2014, 02:54 PM
mrenn's Avatar
Quoted: 3 Post(s)
The quality control issue I believe is the reason they had to bump the price of the FICM's 100$. Either way they have surpassed all my expectations on everything I have ever purchased,or anything I have ever inquired about.Great company.
ARP,EGR Delete,SCT,4.56 gears,powermax,Banks Techni-cooler,Adrenalin HPOP,Donohoe springs,fox shocks,airbags,blue spring,38x15.5 M. Thompson's,4 10's,2 tv's,playstation,amp-steps,2013 tailgate,edge cts
2016 Lariat 6.7.
mrenn is offline
post #10 of 18 Old 02-19-2014, 10:33 PM Thread Starter
Paulliewog's Avatar
Tried starting the behemoth today. Weather was kind of nice, for a Canadian town. Sunny and warmed up above the freezing point. Still takes about 15 seconds of cranking and it starts, runs for about 3 or 4 seconds and quits. Let the glow plugs do their thing again, crank and then about 8 seconds of cranking it fired up and stayed running.
