Bad EGR - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-17-2014, 02:28 PM Thread Starter
Bad EGR
Hello all, 2003 f350 6.0, I was trying to get the egr valve out to clean it and it came apart. not sure if anyones seen anything like this.. I put it back together and it ran like crap. with the tuner of blew white smoke and no power. Put the tuner back on and filled the driveway with blk smoke.. Just ordered another one from Ford.. Hope this is my problem here's some pic'sBad EGR-photo-1.jpg
Captspank is offline
post #2 of 4 Old 02-18-2014, 08:28 PM
Just wondering why did you put it back in there after it fell apart. Hopefully it didnt fall apart inside the intake and suck metal in you valves.
Powerhouse9228 is offline
post #3 of 4 Old 02-19-2014, 06:51 AM Thread Starter
Bad EGR
The lower part of the valve stayed in the intake. I put the upper part back on and tightened it down again not knowing if it was screwed up or not. After I started it and it ran like crap is when I pulled it apart again this time after gently prying on the lower part for 45mins I was able to remove it. Cleaned the hole with a bottle brush and vacuumed everything out as good as I could now just waiting on the new part.
post #4 of 4 Old 02-19-2014, 07:19 AM
I see. I was just going by the pics and thought you pulled it all out at first.. new egr should do the trick.
